Conditional stuff in asm...
Being new to assembler and learning by example, i’m trying to adapt the Tiny Control app.
I’m trying to create a function to display a single-char bar (as on the MidiBox64) using 7 special chars (0x00 to 0x06) and the standard char 0xFF (which is a complete filled bar, that way i save one char).
I got this far and it works pretty well for values under 112 (bars 1-7)
;;  print a parameter bar
;;  IN: number of parameter (0x00-0xff) in WREG
TC_DISPLAY_Page_PrintBar
      lfsr      FSR0, TC_VALUES_BEGIN      ; base address
      movwf      FSR0L                  ; write WREG to FSR0L
      rcall      TC_DISPLAY_Hlp_CalcPtr_VMode      ; get pointer to value mode entry
      tblrd*                              ; read table entry
      ;; move para value to WREG
      movf      INDF0, W
      ;; devide value by 16 = get value in range 0x00 - 0x07
      rrf      WREG, F            ; WREG/2
      rrf      WREG, W            ; WREG/2
      andlw      0x07
;; this is not right... :(
      IFSET      WREG, 0x07, movlw 0xFF
      call      MIOS_LCD_PrintChar
      return
I have trouble coding the condition “if the value is 0x07 use 0xFF instead” for the 8th bar…
Can anyone give me a hand or point me in the right direction with this one?
thanks in advance!
MIOS ROCKS! ;D
You have to use a temporary register like TMP1 or (better) MIOS_PARAMETER1 ..2 or ..3 (which should be prefered for low-level function) to compare the value by using a xor instruction.
Btw: a 8 bit value can also be divided / 16 by using the swapf instruction
And you can write 0xff to a register by using the setf instruction
And you can left out the return by using “goto” instead of “call” (since the function behind the call will execute the return instruction anyhow)
Example:
       swapf   INDF0, W
        andlw   0x07
        movwf   MIOS_PARAMETER1
        xorlw   0x07 ;; result: zero if value matches
        skpnz
        setf    MIOS_PARAMETER1
        movf    MIOS_PARAMETER1, W
        goto    MIOS_LCD_PrintChar
Have fun :slight_smile:
Wild!  ;D
Many thanks for the help (again)!  :)
