Microsoft Windows XP [versão 5.1.2600]
© Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Aliã>cd c:\mios\vmx200
C:\MIOS\vmx200>make
make: *** C:\MIOS\Mios_Base: Invalid request code. Stop.
C:\MIOS\vmx200>set mios
MIOS_BIN_PATH=C:\MIOS\Mios_Base\bin
MIOS_PATH=C:\MIOS\Mios_Base
C:\MIOS\vmx200>make --version
GNU Make 3.81
Copyright © 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i686-pc-msys
C:\MIOS\vmx200>
strange…
thanks again.
Edited:
I dont have mingw installed, i need it?? where i can find? and what version?
because in wiki mingw is installed, look:
C:\MSYS\1.0\bin;C:\Program Files\gputils\bin;C:\Program Files\SDCC\bin; C:\MinGW\bin; C:\Program[bLABLABLA]
I reinstall all again and reupload mios_base_v1_1…
I see some strange stuff in post install of my sys, but is about mingw, and i dont have it, but…
This is a post install process that will try to normalize between
your MinGW install if any as well as your previous MSYS installs
if any. I don’t have any traps as aborts will not hurt anything.
Do you wish to continue with the post install? [yn] y
Do you have MinGW installed? [yn] n
When you install MinGW I suggest you install it to C:/mingw
(replace C: with the drive of your choice). Then create an
/etc/fstab file with a line that has a value similar to:
C:/mingw /mingw
Press ENTER to continue
Normalizing your MSYS environment.
You have script /bin/awk
You have script /bin/cmd
You have script /bin/echo
You have script /bin/egrep
You have script /bin/fgrep
You have script /bin/printf
You have script /bin/pwd
MinGW-1.1 has a version of make.exe within it’s bin/ directory.
Please be sure to rename this file to mingw32-make.exe once youve
echo installed MinGW-1.1 because it\s very deficient in function.
Press ENTER to continue.
