Marxon
1
Hi!
When i try to compile the original Midibox NG app from the SVN then
i get the following error:
First I suspected there is something wrong with my toolchain or system variables but
other MIOS32 apps compile without problems..
Maybe there is a bug in the actual SVN source?
Does anyone else get the same error message?
Best regards
Marxon
T.K
2
You’ve to update the complete repository, not only the application directory.
If this doesn’t help, download the complete repository into a new directory (maybe you did some local changes?)
Marxon
3
Hi Thorsten
Unfortunately this does not help.
EDIT:
I forgot to do a restart after i had changed the system variables.
Now it works!
Thanks a lot.
Marxon
