I’m about to design and etch PCB’s to mount leds and switches to under the frontpanel. It’s kind of a modular pcb with two rows of 4 buttons + LED’s. I want to be able to mount the board in any direction, means 0 degrees or 90 deg. So there are 2 LED’s for each switch (in parallell). You get the point by this picture:
First version:
To ease up the design and reducing jumpers on the board I have connected the LED’s gnd (DOUT) and switches gnd (DIN) together on the PCB. I know this creates a groundloop if I connect the groundpins to both dout and din boards, but should this be a problem ? Or should i just connect it to one ground ?
Maybe I have to split it into two boards, one vertical and one horizontal, to be on the safe side ? ???
What are you’r thoughts about this ?
/Wise
