Coding an Arpeggiator on MIOS 8
Dear Guys
I’ve enhanced a controller for Oberheim Matrix 1000/6 developped by Jackchaos
http://discourse.midibox.org/t/topic/13345
I’d like to code a rather basic arpeggiator as those used in Juno 60. As of today, I’ve “stolen” some code blocks from jambonbill and done an arpeggio : it is automatically synced to external beatclock (if received), UP and DOWN patterns work, speed can be controlled.
I’d like to implement :
UPDOWN patterns, and random
gate time,
hold button.
Here are some relevant extracts of the complete project :
device .c (routing midi received notes)
**//////////////////////////////////////////////////////////////////////////// // Router with arpegiator /////////////////////////////////////////////////////////////////////////// void Router\_Arp(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) { // check if note on or off event at channel 1 has been received if( evnt0 == 0x80 || evnt0 == 0x90 ) { // if note off event: force evnt2 to 0 for easier handling of 'LED off' if(evnt0 == 0x80) evnt2 = 0; } if(router\_arp\_tag == 1){ // arp is activated MIOS\_MIDI\_InterfaceSet(router\_device); // set IIC interface switch( evnt0 & 0xf0 ) { case 0x80: // Note-Off: 3 bytes rem\_arp(evnt0, evnt1, evnt2);//REMOVE NOTE FROM ARP BUFFER return; break; case 0x90: // Note-On: 3 bytes add\_arp(evnt0, evnt1, evnt2); // ADD NOTE FROM ARP BUFFER return; break; case 0xa0: // Aftertouch: 3 bytes case 0xb0: // CC: 3 bytes case 0xe0: // Pitchbend: 3 bytes MIOS\_MIDI\_TxBufferPut(evnt0); MIOS\_MIDI\_TxBufferPut(evnt1); MIOS\_MIDI\_TxBufferPut(evnt2); break; //case 0xc0: // Program Change: 2 bytes :: ignore program change for the moment, will be managed by Chaosmatrix case 0xd0: // Poly Aftertouch: 2 bytes MIOS\_MIDI\_TxBufferPut(evnt0); MIOS\_MIDI\_TxBufferPut(evnt1); break; default: // note: status messages must be handled within MPROC\_NotifyReceivedByte() break; } MIOS\_MIDI\_InterfaceAutoSet(); // switch back to default interface : is in rem\_arp MIDI\_Incoming = 1; } if(router\_arp\_tag == 0){ // arp is desactivated switch( evnt0 & 0xf0 ) { case 0x80: // Note-Off: 3 bytes case 0x90: // Note-On: 3 bytes MIOS\_MIDI\_InterfaceSet(router\_device); // set IIC interface MIOS\_MIDI\_TxBufferPut(evnt0); MIOS\_MIDI\_TxBufferPut(evnt1); MIOS\_MIDI\_TxBufferPut(evnt2); MIOS\_MIDI\_InterfaceAutoSet(); // switch back to default interface MIDI\_Incoming = 1; break; case 0xa0: // Aftertouch: 3 bytes case 0xb0: // CC: 3 bytes case 0xe0: // Pitchbend: 3 bytes MIOS\_MIDI\_InterfaceSet(router\_device); // set IIC interface MIOS\_MIDI\_TxBufferPut(evnt0); MIOS\_MIDI\_TxBufferPut(evnt1); MIOS\_MIDI\_TxBufferPut(evnt2); MIOS\_MIDI\_InterfaceAutoSet(); // switch back to default interface MIDI\_Incoming = 1; break; //case 0xc0: // Program Change: 2 bytes :: ignore program change for the moment, will be managed by Chaosmatrix case 0xd0: // Poly Aftertouch: 2 bytes MIOS\_MIDI\_InterfaceSet(router\_device); // set IIC interface MIOS\_MIDI\_TxBufferPut(evnt0); MIOS\_MIDI\_TxBufferPut(evnt1); MIOS\_MIDI\_InterfaceAutoSet(); // switch back to default interface MIDI\_Incoming = 1; break; default: // note: status messages must be handled within MPROC\_NotifyReceivedByte() break; } } // notify display handler in DISPLAY\_Tick() that DOUT value has changed last\_dout\_pin = evnt1; }**
arp.c (UP & DOWN algo)
#include <cmios.h>
#include "main.h"
#include "arp.h"
#include "mclock.h"
#include "midi.h"
#include "din.h"
unsigned char arp_speed;
unsigned char arp_motif;
unsigned char arp_buffer[32];	// Arp buffer ( 32 should be enough ;) )
unsigned char arp_step; // Arp position (pointer)
unsigned char arp_n; // Arp length
unsigned char arp_tik; // Seq position (ppqn)
unsigned char last_arp; // Last played note
unsigned char add_arp_velocity; // for ARP() et add_arp functions
unsigned char last_played_note;
unsigned char new_note;
unsigned char router_arp_tag; // tag which indicates if arp if active while routing midi events
/// This function activate the arpegiator
void Active_Arp(unsigned char state)
	switch (state){
		case active_arp_on:
			MCLOCK_DoPlay();
			router_arp_tag = 1;
			break;
		case active_arp_off:
			MCLOCK_DoStop();
			router_arp_tag = 0;
			break;
// Arp function
// THIS FUNCTION IS CALLED PERIODICALY BY THE CLOCKBOX
void ARP()
	if(arp_n == 0){
		//	here we could stop the clockbox ;), and restart synced it when buffer != empty
		return; //	ARP BUFFER IS EMPTY
	arp_tik++;
	if(arp_tik >= arp_speed){ // arp speeds : 1/3/6/12/24) :: unsigned char arp_speed is arp_sync_tempo in ui_arp.c
		arp_tik = 0; //reset
		// KILL LAST PLAYED NOTE
		if(last_arp < 0x80){
			MIOS_MIDI_TxBufferPut(last_played_note); // Note on
			MIOS_MIDI_TxBufferPut(last_arp);
			MIOS_MIDI_TxBufferPut(0x00);	//	velocity null (note off)
		// PLAY NEW NOTE
		MIOS_MIDI_TxBufferPut(new_note);	// Note on
		MIOS_MIDI_TxBufferPut(arp_buffer[arp_step]);
		//MIOS_MIDI_TxBufferPut(80);	// VELOCITY MAX
		MIOS_MIDI_TxBufferPut(add_arp_velocity);
		last_arp = arp_buffer[arp_step];	// SAVE LAST PLAYED NOTE
		arp_step++;	// PUSH ARP POINTER
		if(arp_step >= arp_n)
			arp_step = 0;	// LOOP ARP POINTER
	return;
// ADD NOTE TO ARPEGGIO
void add_arp(unsigned char evnt0, unsigned char note, unsigned char evnt2)
	unsigned char i;
	unsigned char swap;
	new_note = evnt0;
	// 1st define the velocity of the note in the arp
	add_arp_velocity = evnt2;
// I SORT NOTES TO GET INTERESTING RESULTS //
		switch(arp_motif){
				if (arp_motif>3) arp_motif = 0;
			case 0:
				// up pattern : tested :)
				for(i=0; i<arp_n; i++){
					if(note < arp_buffer[i]){	// swap
						swap = arp_buffer[i];
						arp_buffer[i] = note;
						note = swap;
				break;
			case 1:
				// down pattern : tested :)
					if(note > arp_buffer[i]){	// swap
						note = swap;
				break;
			case 2:
				// play order : tested :)
						swap = arp_buffer[i-1];	// a->b
						arp_buffer[i-1] = note;	// b->c
						note = swap; // c->a
				break;
			default:
				break;
/*	// updown pattern : to test
			note = swap;
				note = swap;
	arp_buffer[arp_n] = note;
	arp_n++; // INCREMENT ARP NOTE NUMBER COUNTER
#if DEBUG
	MIOS_LCD_CursorSet(0xc0 + LCD_Offset);
	MIOS_LCD_PrintCString("ARP_LEN:");
	MIOS_LCD_PrintBCD2(arp_n);	// SHOW ARP LENGTH
#endif
	return;
//REMove NOTE FROM ARPEGGIO
void rem_arp(unsigned char evnt0, unsigned char note, unsigned char evnt2)
	unsigned char i;
	last_played_note = evnt0;
	for(i=0; i < arp_n; i++) {
		if(arp_buffer[i] >= note)
			arp_buffer[i] = arp_buffer[i+1]; // unstack (swap)
	arp_n--;	// DECREMENT ARP NOTE NUMBER COUNTER
	if(arp_n == 0){	// Kill last played note
		MIOS_MIDI_TxBufferPut(evnt0);	// Note
		MIOS_MIDI_TxBufferPut(last_arp);	// Note Number
		MIOS_MIDI_TxBufferPut(0x00);	// Velocity null
		last_arp = 0x80;	// null note
#if DEBUG
	MIOS_LCD_PrintBCD2(arp_n);//ARP LENGTH
#endif
	return;
ui_arp.c (buttons definition of the control surface)
unsigned char enc_value; // general purpose value for test
unsigned char arp_on; // launch clockbox (PLAY/STOP)
unsigned char arp_mode; // up, down, up-down1, updown2, play_order, random, chord
unsigned char arp_sync_tempo; // 1/32 ... 1 bar
unsigned char arp_gate; // gate time
unsigned char arp_pattern; // defined pattern
unsigned char arp_keysync; // on/off
unsigned char arp_oct; // 1,2,3, octaves
// Display Arp pages,
// page 1
// page 2
// page 3
void UI_Display_Arp()
	switch(SoftPanel.Page)
        case SOFT_PAGE1:
			 ARP PAGE 1
			 01234567890123456789
			 BPM Arpeg Speed
			 ___ On Off d 1/8 u
			MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_PATCH].dout_pin); // off
			MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_EDIT].dout_pin); // off
			MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_ARP].dout_pin); // ON
			MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_OSCILLATORS].dout_pin); // off
			MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_FILTER].dout_pin); // off
			MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_ENVELOPES].dout_pin); // off
			MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_KEYBOARD].dout_pin); // off
			MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_MATRIX].dout_pin); // off
            MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_PAGE].dout_pin); // on
            MIOS_LCD_Clear();
			//1st line
            MIOS_LCD_CursorSet(0 + LCD_Offset);
            MIOS_LCD_PrintCString("BPM Arpeg Speed ");
			MIOS_LCD_CursorSet(64 + LCD_Offset);
			if (external_clk_received == 1){
				MIOS_LCD_PrintCString("EXT"); // print EXT for BPM
			}else{
				MIOS_LCD_PrintBCD3(bpm);
			MIOS_LCD_CursorSet(69 + LCD_Offset);
			MIOS_LCD_PrintCString("On Off");
			MIOS_LCD_CursorSet(64+14 + LCD_Offset);
			MIOS_LCD_PrintBCD2(arp_speed);
			MIOS_LCD_CursorSet(64+13 + LCD_Offset);
			MIOS_LCD_PrintChar(CHAR_DOWN);
			MIOS_LCD_CursorSet(64+19 + LCD_Offset);
			MIOS_LCD_PrintChar(CHAR_UP);
			break;
		case SOFT_PAGE2:
			 ARP PAGE 2
			 BPM Oct - Motif
			 ___ On Off d Up u
            MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_PAGE].dout_pin); // off
            MIOS_LCD_Clear();
			//1st line
            MIOS_LCD_PrintCString("BPM Oct - Motif ");
			}else{
			//MIOS_LCD_PrintBCD3(bpm);
			MIOS_LCD_PrintBCD1(arp_oct);
			MIOS_LCD_PrintBCD2(arp_motif);
			break;
// Configure Arp pages
void UI_Handle_Arp()
	if(SoftPanel.Page == SOFT_PAGE1){
		switch (SoftPanel.Button){
            case DIN_PAGE:
                SoftPanel.Page = SOFT_PAGE2;
				break;
            case SOFT_EDIT_1: //
                // do stuff
				break;
			case SOFT_EDIT_2: //
                // do stuff
				Active_Arp(active_arp_on);
				break;
			case SOFT_EDIT_3: //
                // do stuff
				Active_Arp(active_arp_off);
				break;
			case SOFT_EDIT_4: //
                // do stuff
				arp_speed--;
				break;
			case SOFT_EDIT_5: //
                // do stuff
				arp_speed++;
				break;
			case SOFT_EDIT_INC: // increment
				break;
			case SOFT_EDIT_DEC: // decrement
				break;
		// encoder : set BPM :: WORK :)
		if(bpm < 50)
			bpm = 50;
		if(bpm > 250)
			bpm = 250;
        bpm += SoftPanel.EncoderValue;
		bpm = (unsigned int)MCLOCK_BPMGet()-48;
		MCLOCK_BPMSet((unsigned char)bpm+48) ;
		// realtime display feature
		app_flags.Display_DIN_Req = 1; // MUST HAVE or BPM encoder value not realtime print
	  else {
			case DIN_PAGE:
                SoftPanel.Page = SOFT_PAGE1;
				break;
            case SOFT_EDIT_5: // increment arp_motif
				  arp_motif++;
				  if(arp_motif > 5)
					  arp_motif = 5;
				break;
			case SOFT_EDIT_4: // decrement arp_motif
				  arp_motif--;
				  if(arp_motif > 5)
					  arp_motif = 0;
				  break;
				// do stuff
				break;
				// do stuff
				break;
		  if(bpm < 50)
			  bpm = 50;
		  if(bpm > 250)
			  bpm = 250;
mclock.c (the seq core) copied to TK basic clockbox
// Include files
#include <cmios.h>
#include <pic18fregs.h>
#include "main.h"
#include "mclock.h"
#include "device.h"
#include "arp.h"
#include "din.h"
// Global variables
mclock_state_t mclock_state; // the mclock state variable
mclock_pin_state_t mclock_pin_state; // state of the clock output pin
unsigned char mclock_tick_ctr; // requests MIDI clocks
unsigned char external_clk_received; // external clock event tag
unsigned char bpm; // holds the current BPM setting
unsigned char mclock_ctr_24; // counts from 0..23
unsigned char mclock_ctr_beats; // counts the quarter notes 0..3
unsigned char mclock_ctr_measures; // counts the measures (up to 65535)
// Local variables
// This function initializes the MIDI clock module
void MCLOCK_Init(void)
  mclock_state.ALL = 0;
  mclock_pin_state.ALL = 0;
  mclock_tick_ctr = 0;
  MCLOCK_ResetMeter();
// This function should be called from USER_Tick to send MIDI clock and
// MIDI Clock Start/Stop/Continue
void MCLOCK_Tick(void)
  // start request? Send 0xfa and enter RUN mode
  if( mclock_state.START_REQ ) {
    mclock_state.START_REQ = 0;
    MIOS_MIDI_TxBufferPut(0xfa);
    mclock_state.RUN = 1;
    // request display update
    app_flags.DISPLAY_UPDATE_REQ = 1;
  // continue request? Send 0xfb and release pause
  if( mclock_state.CONT_REQ ) {
    mclock_state.CONT_REQ = 0;
    MIOS_MIDI_TxBufferPut(0xfb);
    mclock_state.PAUSE = 0;
  // stop request? Send 0xfc and leave RUN mode
  if( mclock_state.STOP_REQ ) {
    mclock_state.STOP_REQ = 0;
    MIOS_MIDI_TxBufferPut(0xfc);
    mclock_state.RUN = 0;
    mclock_tick_ctr = 0; // prevent that any requested 0xf8 will be sent
  // send 0xf8 until counter is 0
  while( mclock_tick_ctr ) {
//-------> do not send midi clock to i2c to avoid problem with M1000 : it doesn't like too much data //
/* MIOS_MIDI_InterfaceSet(0x00); // route F8 to default midi out
	  MIOS_MIDI_TxBufferPut(0xf8);
	  MIOS_MIDI_InterfaceSet(router_device);
	// decrementing the counter *MUST* be an atomic operation, otherwise it could
    // conflict with MCLOCK_Timer()
    // however, I guess that the compiler will generate a single decf instruction,
    // which is atomic... but better to write it in this way, who knows, how SDCC
    // will behave in future...
    INTCONbits.GIE = 0; // disable interrupts
    --mclock_tick_ctr;
    INTCONbits.GIE = 1; // enable interrupts
    // increment the meter counters
	ARP();//ARPEGGIATOR
    if( ++mclock_ctr_24 == 24 ) {
      mclock_ctr_24 = 0;
      if( ++mclock_ctr_beats == 4 ) {
	mclock_ctr_beats = 0;
	++mclock_ctr_measures;
	// heartbeat tempo led :
	  if(mclock_ctr_24 == 0){
		  MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_SHIFT].dout_pin); // HeartBeat
	  }else{
		  MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_SHIFT].dout_pin); // indicates Off
// This function should be called from USER_Timer to update the MIDI clock
void MCLOCK_Timer(void)
  // just increment a clock counter if in RUN and not in PAUSE mode
  // it will be decremented in MCLOCK_Tick - each step sends one 0xf8 event
  // the advantage of this counter is, that a clock event can never get
  // lost, regardless how much the CPU is loaded
  // (however, in this application the CPU is very unbusy, but I prepared
  // this for even more complex programs...)
  if( mclock_state.RUN && !mclock_state.PAUSE) {
    ++mclock_tick_ctr;
    mclock_pin_state.CLK_REQ = 1;
// This internal function divides 3125000 / BPM
// The formula:
// -> delay = 60 / BPM * 24
// timer is clocked at 10 MHz, and we are using a 1:8 prescaler
// -> timer cycles = ((60/BPM*24)/8) / 100E-9
// -> 3125000 / BPM
// the 24 Bit / 16 Bit division routine has been created by Nikolai Golovchenko,
// and is published at:
// http://www.piclist.org/techref/microchip/math/div/24by16.htm
unsigned char AARGB0;
unsigned char AARGB1;
unsigned char AARGB2;
unsigned char BARGB0;
unsigned char BARGB1;
unsigned char LOOPCOUNT;
unsigned char REMB0;
unsigned char REMB1;
unsigned int MCLOCK_GetTimerValue(unsigned char bpm)
  //;Inputs:
  //; Dividend - AARGB0:AARGB1:AARGB2 (0 - most significant!)
  //; Divisor - BARGB0:BARGB1
  //;Temporary:
  //; Counter - LOOPCOUNT
  //; Remainder- REMB0:REMB1
  //;Output:
  //; Quotient - AARGB0:AARGB1:AARGB2
  LOOPCOUNT = 24;
  AARGB0 = (unsigned char)(3125000L >> 16L);
  AARGB1 = (unsigned char)(3125000L >> 8L);
  AARGB2 = (unsigned char)(3125000L >> 0L);
  BARGB0 = 0;
  BARGB1 = bpm;
  REMB0 = 0;
  REMB0 = 1;
__asm
      banksel _LOOPCOUNT;
        CLRF _REMB0
        CLRF _REMB1
        MOVLW 24
        MOVWF _LOOPCOUNT
LOOPU2416:
        RLCF _AARGB2, W ;shift dividend left to move next bit to remainder
        RLCF _AARGB1, F ;
        RLCF _AARGB0, F ;
        RLCF _REMB1, F ;shift carry (next dividend bit) into remainder
        RLCF _REMB0, F
        RLCF _AARGB2, F ;finish shifting the dividend and save carry in AARGB2.0,
                                ;since remainder can be 17 bit long in some cases
                                ;(e.g. 0x800000/0xFFFF). This bit will also serve
                                ;as the next result bit.
        MOVF _BARGB1, W ;substract divisor from 16-bit remainder
        SUBWF _REMB1, F ;
        MOVF _BARGB0, W ;
	SKPC ;
        INCFSZ _BARGB0, W ;
        SUBWF _REMB0, F ;
;here we also need to take into account the 17th bit of remainder, which
;is in AARGB2.0. If we dont have a borrow after subtracting from lower
;16 bits of remainder, then there is no borrow regardless of 17th bit
;value. But, if we have the borrow, then that will depend on 17th bit
;value. If it is 1, then no final borrow will occur. If it is 0, borrow
;will occur. These values match the borrow flag polarity.
        SKPNC ;if no borrow after 16 bit subtraction
         BSF _AARGB2, 0 ;then there is no borrow in result. Overwrite
                                ;AARGB2.0 with 1 to indicate no
                                ;borrow.
                                ;if borrow did occur, AARGB2.0 already
                                ;holds the final borrow value (0-borrow,
                                ;1-no borrow)
        BTFSC _AARGB2, 0 ;if no borrow after 17-bit subtraction
         BRA UOK46LL ;skip remainder restoration.
        ADDWF _REMB0, F ;restore higher byte of remainder. (w
                                ;contains the value subtracted from it
                                ;previously)
        MOVF _BARGB1, W ;restore lower byte of remainder
        ADDWF _REMB1, F ;
UOK46LL:
        DECFSZ _LOOPCOUNT, f ;decrement counter
         BRA LOOPU2416 ;and repeat the loop if not zero.
      movff _AARGB1, _PRODL
      movf _AARGB2, W
      return
__endasm;
 return 0; // dummy return
// These functions are used to set/query the BPM
void MCLOCK_BPMSet(unsigned char _bpm)
  // re-init timer depending on new BPM value
  bpm = _bpm;
  MIOS_TIMER_ReInit(3, MCLOCK_GetTimerValue(bpm));
unsigned char MCLOCK_BPMGet(void)
  return bpm;
// This function resets the mclock_ctr variables
void MCLOCK_ResetMeter(void)
  mclock_ctr_24 = 0;
  mclock_ctr_measures = 0;
// This function sends the current song position
void MCLOCK_SendMeter(void)
  unsigned int songpos = (mclock_ctr_beats << 2) | (mclock_ctr_measures << 4);
  MIOS_MIDI_TxBufferPut(0xf2);
  MIOS_MIDI_TxBufferPut((unsigned char)(songpos & 0x7f));
  MIOS_MIDI_TxBufferPut((unsigned char)(songpos >> 7) & 0x7f);
// These functions are used to control the MCLOCK handler from external
void MCLOCK_DoStop(void)
  if( mclock_state.RUN == 0 ) {
    // reset song position of already in stop mode
    // send Song Position
    //MCLOCK_SendMeter();
  // request stop
  mclock_state.STOP_REQ = 1;
void MCLOCK_DoPause(void)
  // if in RUN mode:
  if( mclock_state.RUN ) {
    // toggle pause mode
    if( mclock_state.PAUSE ) {
      mclock_state.CONT_REQ = 1;
    } else {
      mclock_state.PAUSE = 1;
  } else {
    // Stop mode: just toggle PAUSE
    mclock_state.PAUSE = mclock_state.PAUSE ? 0 : 1;
void MCLOCK_DoPlay(void)
  // reset meter counters
  // request start
  mclock_state.START_REQ = 1;
main.c (get note from external midi keyboard)
// This function is called by MIOS in the mainloop when nothing else is to do
void Tick(void) __wparam
	// the timing of delayed midi transmits is a low priority
	LivePanel_HandleTransmitDelay(); // live panel
	MIDI_HandleMatrixModTransmitDelay(); // from soft panel
	MIDI_HandleDelayedVoiceParam(); // from soft panel
	MIDI_HandleFilterSustainTransmitDelay(); // from live panel
	// this routine sends the MIDI clock (and Start/Continue/Stop) if requested
	MCLOCK_Tick();
// This function is periodically called by MIOS. The frequency has to be
// initialized with MIOS_Timer_Set
void Timer(void) __wparam
	LivePanel_BlinkLFOs();
	LivePanel_BlinkLEDs();
	// forward timer event to MIDI clock module (-> mclock.c)
	if(external_clk_received == 0){
		MCLOCK_Timer();
	}else{
// This function is called by MIOS when the display content should be
// initialized. Thats the case during startup and after a temporary message
// has been printed on the screen
void DISPLAY_Init(void) __wparam
	MIOS_LCD_Clear();
	app_flags.Display_Pot_Req = 0;
	// start by displaying patches
	last_din_pin = DIN_PATCH;
// This function is called in the mainloop when no temporary message is shown
// on screen. Print the realtime messages here
// the live panel should only display on the lcd when we're in patch mode.
void DISPLAY_Tick(void) __wparam
	// display encoder movements
	if( app_flags.Display_ENC_Req ) {
		if(last_encoder == ENCODER_SOFT)
			SoftPanel_DisplayHandler();
		else // dco encoders
			if (SoftPanel.Mode == Patch)
                Encoders_DisplayOscFrequency(last_encoder);
		app_flags.Display_ENC_Req = 0; // handled
	// display analog pot movements
	if( app_flags.Display_Pot_Req && SoftPanel.Mode == Patch)
		LivePanel_DisplayAin();
		app_flags.Display_Pot_Req = 0; // handled
	// display buttons
	if( app_flags.Display_DIN_Req )
		if(DIN_ConfigMap[last_din_pin].group == BUTGRP_LIVE && SoftPanel.Mode == Patch )
            LivePanel_DisplayDin(last_din_pin);
        else
            SoftPanel_DisplayHandler ();
		app_flags.Display_DIN_Req = 0; // handled
// This function is called by MIOS when a complete MIDI event has been received
void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam
	unsigned char evnt0_; // reNormed midi bytes
	unsigned char evnt2_;
	// real note off msg (to use a Roland Juno2 as a keyboard for example):
	switch(evnt0 & 0xf0){
		case 0x90:
			if(evnt2 == 0){
				evnt0_ = (evnt0 - 0x10);
				evnt2_ = evnt2;
			else{
				evnt0_ = evnt0;
				evnt2_ = evnt2;
			break;
		default:
			evnt0_ = evnt0;
			evnt2_ = evnt2;
			break;
	Router(evnt0_, evnt1, evnt2_); // see -> device.c
	Router_Arp(evnt0_, evnt1, evnt2_); // see arp.c
// This function is called by MIOS when a MIDI event has been received
// which has been specified in the MIOS_MPROC_EVENT_TABLE
void MPROC_NotifyFoundEvent(unsigned entry, unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam
// This function is called by MIOS when a MIDI event has not been completly
// received within 2 seconds
void MPROC_NotifyTimeout(void) __wparam
// This function is called by MIOS when a MIDI byte has been received
void MPROC_NotifyReceivedByte(unsigned char byte) __wparam
    static unsigned char fx_status;
    if(MIDI_ReceivingEditBuffer)
        MIDI_HandleEditBuffer(byte); // call HandleEdiBuffer to get EditBuffer param/values
    else if(MIDI_ReceivingBank)
		MIDI_HandleBankDump(byte); // call HandleBankDump to get EditBuffer of Bank patches
	else
        // normal MIDI events are forwarded in MPROC_NotifyReceivedEvnt
        // this function handles sysex and realtime messages
        if( byte & 0x80 ) { // Status message
            if( byte >= 0xf0 )
            MIOS_MIDI_TxBufferPut(byte); // transfer byte
			if(byte == 0xf8){
				external_clk_received = 1;
				++mclock_tick_ctr; // to control the arpegiator clock externally
			}else{
				external_clk_received = 0;
        // determine status
        if( byte == 0xf0 ) {
            fx_status = 0xff; // forward until 0xf7
            } else if( byte == 0xf7 ) {
              fx_status = 0; // f7 reached, no forward
            } else if( byte == 0xf1 || byte == 0xf3 ) {
              fx_status = 1; // expecting one additional byte
            } else if( byte == 0xf2 ) {
              fx_status = 2; // expecting two additional bytes
            } else {
              fx_status = 0; // expecting no additional byte
        else
            // check if fx status active
            if( fx_status ) {
                // forward data byte
              // decrement counter if required
                if( fx_status != 0xff )
                    --fx_status;
	// update display
//	if(!external_clk_received)
// app_flags.Display_DIN_Req = 1; // DON'T WORK MAKE DISPLAY SHINING ALL TIME
The whole project code is available below for reference.
Thanks for your help and interest :flowers:
[MatrixBoxSource_JV_beta v0.80_ext_clk.zip](< base_url >/applications/core/interface/file/attachment.php?id=8864)
Great project, an arpeggiator seems to be very useful with the Matrix! I love the one on my K5k…
