clockbox with audio metronome? (syncing drummer to Midi clock)
Hi folks,
Is there a way to syncronize a (human) drummer to a (not finished) clockbox?
I’m thinking of using to DOUTs connected to two of them to trigger two different “click-types” which will then be given to the drummers monitoring system.
I’m pretty shure that this can be realized with midibox, so the only question is: Do you have different (better) ideas to realize something like this? (…and: no. I don’t want to get answers like “Have you heard of the MB-808”  ;D)
regards
matthias
/edit: typo
[ot-mode]Synchronize a human drummer? Hmm, I don’t think the 5V from a DOUT will work as electro-shocks. Needs More PowerTM[/ot-mode]
lets change the question:
any serious ideas?  ;D
Step 1 - Mod clockbox to send midi pulses. C3 every 1/4 note, C4 every whole note.  **
Step 2 - find the shittiest cheapest midi enabled sound device you can. That’s your new metronome.
Step 3 - get/make a crappy cheap 2*stereo channel mixer for your drummer’s cans (no need to waste a mixer channel and rob him of the ability to control it’s volume himself)
Find this in mclock.c:
      if( ++mclock_ctr_beats == 4 ) {
		mclock_ctr_beats = 0;
		++mclock_ctr_measures;
    // send clocks
    MIOS_MIDI_TxBufferPut(0xf8);
Do this:
      // send high metronome and set MTC counters
      if (++mclock_ctr_beats == 4 ) {
          MIOS_MIDI_TxBufferPut(0x90);
          MIOS_MIDI_TxBufferPut(0x3C);
          MIOS_MIDI_TxBufferPut(0x3F);
      // send low metronome
      if (mclock_ctr_beats)  {
          MIOS_MIDI_TxBufferPut(0x48;
    // send clocks
and find this:
MIOS_MIDI_TxBufferPut(0xfa)
and replace it with this:
// send start message and high metronome
          MIOS_MIDI_TxBufferPut(0x48);
          MIOS_MIDI_TxBufferPut(0x3f);
You could use an extra DIN (seeing as it’s not done yet) as a switch to set a variable and turn it on and off.
You could replace the midi messages with DOUT pulses
You could put menus and stuff in, and dividers.
Go crazy :slight_smile:
Check this code, I wrote it off the top, and into the forum, it’s not tested :wink:
“What IDE do you use?”
“SMF.”
“Oh.”
