clockbox in MTC help!
hi
i have built a clockbox with 8 outputs and menu buttons. If i use v1.1c the multiple outputs won’t work.
Is there anyone who has the code for the clockbox which operates with MTC and 8 out, or can help me to program this.
thanks,
Joente
The clockbox firmware with 9 MIDI OUTs and MTC support is called “clockbox_enhanced_v1c”
thank you thorsten for the reply.
I’ve tried the enhanced version but the multi output won’t work in mtc mode, in midi clock mode there’s no problem.
Ok, now I understand the issue.
No, nobody implemented a MTC to MIDI Clock converter yet.
