Due to a lot of requests and documentation problems, next weekend I will clean up the MIDIbox64, MIDIbox16E, MIDIbox MF firmwares.
Beside of the known features the new versions will provide:
- 64 Buttons (2 DINX4 modules)
- 64 LEDs (2 DOUTX4 modules)
- Device Numbers
- a new SysEx dump structure (sorry, Serge!)
The motorfader and sequencer part will be removed from the MIDIbox64 firmware.
Tomorrow a first version of MIDIbox64SEQ will be available
with a new handling and new functions:
- 4 Tracks with 3 Layers (for Note Number/CC Number/Velocity/Gatelength/…)
- Seperate Transposer/Arpeggiator for each Track
- independent clock divider and direction flags (Forward/Backward/PingPong/Random) for each Track
- Pot-Rows can also be assigned to common controller functions, so that you can control the parameters of your synthesizers and play sequences with one MIDIbox at the same time
A later version will also provide 64 LEDs, so that every pot has it’s own LED.
