Two sets. Both have faults, so both cheap.
Set #1 -
Perfect, except for 5 holes not cut. This would be a pretty easy job to resolve - print out the panel on paper, overlay it, centermark the five holes, and drill them.
With care, would result in a perfect panel, with not a whole load of effort.
Photos -
Set #2 -
Call it a Halloween set? Gouged by the cutter. Is what it is. Good to be used, without any manipulation (ie you dont need to drill this one - its all spot on, except for the ‘wound’)
Rear panel is not in the photo, but its included, and is fine (only the top got damaged)
Photo -
(i know there’s only one photo, but the others were all wrong - ill try again if youre keen)
Price -
GBP 65 per set (ex delivery / fees)
Both sets are the same cost, so its 100% up to you if you would like to drill the first set, and go that way, or would like to just have a panel that fits ‘out of the box’
