I’m chaining 4 core modules through midi-out to midi-in method. 3 modules will be running midio128, the other one will be running a custom C application. I know that enabling the midi merger in midio128 will ensure that messages get passed between cores. What do I need to do in my C application to make sure it also behaves in this way?
Thanks,
James
Hi James,
you just need to set MIOS_MIDI_MergerSet(0x01) to enable forwarding, see function_reference:
MIOS_MIDI_MergerSet
C_DECLARATION void MIOS_MIDI_MergerSet(unsigned char mode)
DESCRIPTION configures the integrated MIDI merger following Merger IDs are provided:
0x00: MIOS_MIDI_MERGER_DISABLED (merger disabled)
0x01: MIOS_MIDI_MERGER_ENABLED (merger enabled)
0x02: MIOS_MIDI_MERGER_MBLINK_EP (MIDIbox Link End Point)
0x03: MIOS_MIDI_MERGER_MBLINK_FP (MIDIbox Link Forwarding Point)
C_IN merger function ID in <mode>
C_EXAMPLE
// configure the MIDIbox as MIDIbox Link End Point
// (means: merger enabled only for events which has
// been generated by another MIDIbox which is configured
// as MIDIbox Link Forwarding Point)
MIOS_MIDI_MergerSet(MIOS_MIDI_MERGER_MBLINK_EP);
Cheers,
Michael
