Is it possible to cast from Char to Int?
Like:
unsigned char a = 5;
unsigned int b = 1000;
int c = b * (int)a;
When I try to do such a thing I get the following error when running make:
Compiling main.c
Processor: 18F452
Linking project
error: missing definition for symbol "__mulint"
ERROR!
Never mind, I found this document.
http://www.midibox.org/dokuwiki/doku.php?id=stryd_one_codeblocks
Which introduces me to Code:Blocks and I believe the included LIB is what’s helping me.
You guys are great.
why would you want to store an int in a var char?
I have a lookup table filled with unsigned chars that define the config and behavior of each and every pot. One of the items is a refresh interval that later gets multiplied by 500 (this may change later).
This is the only way I can see how to do it… and yes, I’m doing a multiplication the bad way (a = b*c).
http://www.midibox.org/dokuwiki/doku.php?id=c_tips_and_tricks_for_pic_programming
see Arithmetic Calculations
I’m at work right now, but from what I see in this document. If I change my 500 (above) to 512
and do a bit shift like so:
a = 2 << 9; // a is 1024
or
a = 5 << 9; // a is 2560
This would be the equivalent of:
a = 2 * 512;
or
a = 5 * 512;
If this is true, I’ve solved that problem and I can make the changes when I get home.
Thanks again!
( audiocommander, yes. I meant ‘a = 2 * 512;’, It’s corrected above. Thanks. )
I’m sure you mean a = 2 * 512, then it’s correct and you’ll save a lot of codespace and calculating power this way
Cheers!
Michael
out of sheer morbid curiosity - why store the var in a char and not an int?
unsigned char two_dimensional_array[NUM_POTS][NUM_OPTIONS]
The array can only hold one value type. I’m storing all my config here and every value is a char.
I want the option to scale all the update intervals so the interval is later multiplied by another number which is higher than 255.
cheers - that makes sense to me now…
