I used a virgin pic, flashed bootloader 1.2b using mplab and picstart plus programmer.
In mios studio -
received unexpected mios sysex message
= 00007E407001F7 expected = 00007E4000
And the midi in monitor shows the 00007E407001F7 coming in every 2 seconds
I also tried another pic with the same process as above…
How can I solve this?
nILS
2
You get an upload request - to me it seems like the PIC has the device ID set to 1, that’s why you get 00007E400 1 instead of 00007E400 0.
Someone correct me if I’m wrong =)
T.K
3
Yes, thats correct. It’s the PICstart issue, the programmer doesn’t write the correct ID (all-zero in normal case)
The workaround is described under the TEST_SW2 topic of this page: http://www.ucapps.de/howto_debug_midi.html
