Can't d/l VMB!
http://mios_tools.midibox.org:80/  doesn’t work, could someone help me?
Thank u in advance!
remove the :80 and it will work
Nope!
It doesn’t work here.
Hmm..
It’s a redirect to http://www.midibox.org/mios_tools/
Browsers should support it and if it’s disabled at least give a link to the correct document..
User manual links for vMIDIbox64 & vMIDIbox64E give a 404 - but I guess this is just because documentation isn’t ready yet. :wink:
aleintrance - If you can’t get link to work, just PM me with your email address, and I’ll mail you what you want.
Bye, Moebius
thank u moebius!
The link to the version c is working, but the link to version b tells ‘service not available’ (not 404) probably it’s the same file redirected from http://mios_tools.midibox.org/
Anyway I’ve d/led the version c
Thank u
I got that message too (on the first attempt to DL vMIDIbox64E) - but the trick is trying again :wink: It worked instantly in the second try, just a few seconds later.
So, just click again.. if you didn’t get the version you needed :wink:
Must have something to do with the server resource handling..? TK?
Bye, Moebius
Oki moebius!
After 5/6 attempts also the b verion was d/l.
Thank u for your patience.
