Hey everyone. I have a fully working Core with GM5, but I’d like to swap the GM5 to EEPROM mode so I can name the Midi Device and change it’s I/Os to 1 (I know I can do this physically, but I’m going to be using two GM5’s so want them named properly as well).
I’ve installed GPUTILS and SDCC which both seem to be installed properly, but when I download the SVN of mbhp_usb_gm5_eeprom and try to run “make” in terminal, I get this error:
Makefile:28: /include/makefile/common.mk: No such file or directory
Makefile:31: /modules/app_lcd/dummy/app_lcd.mk: No such file or directory
Makefile:34: /modules/iic_eeprom8/iic_eeprom8.mk: No such file or directory
make: *** No rule to make target `/modules/iic_eeprom8/iic_eeprom8.mk'. Stop.
Is the SVN thats up correct, or is my install borked?
You have to set the following two environment variables to the path of your mios/trunk directory.
Example:
export MIOS_PATH=~/svn/mios/trunk
export MIOS_BIN_PATH=$MIOS_PATH/bin
[/code]
(~ is a shortcut to your /Users/\<your-login\> directory)
The export commands can be executed in the same shell where you will execute "make".
Alternatively you can enter the commands into your ~/.bash\_profile file, so that they will be executed whenever a new terminal is opened.
Adding those two lines to my bash_profile worked perfectly. I haven’t tested the result on the Core/GM5 yet, hopefully I’ll get the chance tonight/tomorrow, but the “make” works fine now.
