I have finally recieved my Reichelt order and finished some modules of the project! I mounted these on a wooden board, for testing purposes:
As you can see, only the LCD and the Midi IN/OUT are connected. I have programmed the bootstrap into the PIC18f with my JDM. After this, I turned on the power to the core and within 2 seconds uploaded MIOS 1.2.
So far so good, but now, when I turn on the power, it just keeps resetting every few seconds, telling me this over and over:
I tried sending the ain64_din128_dout128_v1_1 sysex, but nothing happens. What should I do to get an application in the pic? Connect the other modules first?
My plans were actually to build a MidiBox64 but it is only now that I discover that this will not run on a Pic18f? I need to write my own MidiBox64 mios application?
No, the bootstrap loader isn’t the problem. I guess that the application fails since the open analog pins are not connected to ground. Did you also try another application, for example the DOUT test, just to check if anything is running ok? Which messages appear during the MIOS upload, do you see any “…0E xx F7” error message?
Since the SID control surface is nearly finished, it cannot get that long
P.S.: are you able to increase the input voltage to the core module? Maybe the backlight consumes too much power that Vdd sinks below 5V and the PIC will be reset!
First of all I have tried to up the adapter output to 9 volts. Nothing different. It really looks like the Pic is resetting itself all the time.
I don’t think it even notices that I am uploading an app via sysex, I don’t see any error messages or ok messages…? The resetting cycle even continues while I am uploading a sysex file.
Can there be a faulty connection? Is there a spot to measure for voltages?
You wrote that a copyright message appears, thereafter the PIC will be reset. Is this still the case? This would mean that you were able to upload MIOS itself once. It would be interesting for me, if the complete OS has been uploaded, means: I want to see all the “acknowledge” messages which are sent during the upload of the operating system. You will not be able to upload an application if MIOS is not complete, e.g. because of an error during the first upload procedure (this could also explain why the PIC will be reset)
Ok, so just try the MIOS upload again. If this doesn’t work anymore, you’ve possibly problems with the MIDI-In connection (from the Rx pin of the PIC to the MIDI-In of your PC) - in this case I can give you some more infos, how to debug the hardware…
Turned on the box. The LCD is filled with
Immediately pressed SEND in midiOx sysex window (where mios 1.2 syx is loaded)
The screen stays filled with the #'s during the upload (where it would normally go on a show the copyright notice), so something is being received.
When midiOx finishes, the copyright notice appears for one second. Then the screen goes blank for three seconds. Then the copyright notice appears again for one second etcetera.
Here is a photo of my midi plugs, just for the record:
I have emailed you the midiOx Output Monitor data.
So it seems that the bootloader receives anything, but it never returns an acknowledge. Such a behaviour could be related to a MIDI-Ox setup or MIDI driver problem (e.g. the USB-MIDI driver from Microsoft corrupts also the messages if the buffer size is smaller than the SysEx string).
Could you please try following settings (SysEx configuration menu of MIDI-Ox):
Low Level Output Buffer Size: 2048
Low Level Output Buffer Num: 32
Delay after F7: 750 ms (just to ensure, you could also increase this delay, but 750 ms should work ok)
Another usefull test: connect the MIDI-Out of your PC with the MIDI-In (feeback loop). Load a .syx file and start the “Send/Receive” function under “Command Window->Send/Receive SysEx”. The number of received bytes should match with the number of transmitted bytes. If this value doesn’t match, the driver of your MIDI interface defenitely has a bug (for which the increased buffer size could be a workaround)
To make sure my midi is working, I connected my midi keyboard to the same midi plugs.. Both midi IN and OUT seem to be working just fine. However, I find it strange that when I press a key on my midi keyboard, it appears in both the input and output monitor windows of midiOx?
After verifying my midi (It’s actually my sound card’s game port, dunno what you mean with “the USB-midi driver from microsoft”?) I applied the Low Level Output Buffer settings in the Sysex config of midiOx.
Then I tried uploading MIOS 1.2 again. The same happened, but it seems that the time between the resets is shorter now… ?
Connecting the MIDI-Out with the MIDI-In (feeback loop) results in a “0 bytes received” message.
Thanks for your help so far, I’m sure we’ll find a solution. Unfortunately I have to go now so I’ll try more this weekend (saturday afternoon).
ok, the keyboard test showed that the input port is mapped to the output port. This is some kind of internal feedback which definitely disturbs the upload.
So, go into the Options->MIDI Devices menu, disable the “automatically attach inputs to outputs” switch, open the port map of the MIDI out and remove the MIDI In from this map. This should (hopefully) help
Thorsten, I have applied the settings, like you said. With my Roland MIDI keyboard attached to my PC’s MIDI in and MIDI out ports I can now see the keys I’m pressing on the Roland appear in the Input monitor. Also, I can use the Midi Ox “play notes from the computer keyboard” option to trigger stuff on my Roland. So this means my Midi Setup is OK now I guess.
Then I tied midi in to midi out (feedback loop), loaded a SYX file and pressed send/receive in MidiOx. Bytes received equals bytes sent. Must be OK as wel..!
Then I tried to upload Mios to my Core Module. After the sysex send, the Core keeps resetting itself again with the Copyright T.Klose message.
Oh, and during the sending of the sysex, no data (acknowledge messages) shows up in the input window of midiOx. However, the “start upload” message does appear when I turn on power to the core, so midi out IS working…
I had this same problem, u should really check your MIDI in jack as that is where my problem was. Also use the send/recieve command in the sysex window then paste the results to this forum, and maybe we can help from there.
Well my friends, it seems like I’ve finally got things working! Â ;D
What was wrong? I don’t know. Did two things at the same time. I re-programmed the bootstrap loader and while waiting for the programming in progress, I decided to apply some extra (fresh) solder to some of the pads on the core module. So it was either a bad solder connection or a bad bootstrap loader in my PIC (I am betting on that last one)…
Anyway, after re-inserting the PIC in the core and then while sending the Mios 1.3 sysEx (just released today) I started seeing acknowledge messages at last!!
And then when I saw this, a big smile appeared on my face  :D
Finally, I must have had a corrupt OS, or bootstrap.
I completely erased the bootstrap, sent all the info, which verified, and I am now on the MIOS. The MIOS is working, I am getting the verification back as suggested on the bottom of the Introduction page.
I am currently working out some bugs, I have the Mios screen that keeps jumping back from
Mios v1.3 by TK and waiting for a DIN or AIN. It seems to be random received events, so I am unsure if I had correctly hooked up the DIN and DOUT.
The question I had is what to do with pin 9 (OB) if I was only using a single Dout?
ICprog verified the burning of the chip and I had also read it back in. Mios seemed to load with all “0f”, but now I cannot get Mios to send back (F0 00 00 7E 40 00 0F F7).
Another thing that is happening is that I sometimes get random events (which I still get). Voltage at VDD is at 5v, the only other thing I can think is the optocoupler. I tested my 5.6k ohm and it came up to 6k ohm, but besides that I have no idea what could be causing the problems.
I am totally stumped why my buttons wont work, and i cannot get verification back from MIOS.
well TK must be a better helper than me but… I’ll try to help you!
So you say you think you upload an application, but which one? (see MIOS->download and try a test program).
If you have just upload mios via sysex, you would see the copyright screen, and then just “Ready”… and then you can upload an application. I don’t see what “waiting or DIN, AIN event” comes from… try a test program (upload with sysex) like ain_example1_v1_3 if you have pot, or enc example ect
