cannot get the slave to do the work!!!!
i have two cores+2 sid modules (+control surface, step B) working and tested both standalone, i’m working on set up them as master+slave.
i think i did all the relevant steps, but i cannot get any signal from the slave
so the situation is this
  1. the two core+sid are working good when they are standalone, so all is good from this side. i burned sid 1.6 (mios 1.7) on both, with sid 8580 and control surface
  2. i took one PIC and changed the ID from 0 to 1 with midiOX with the string F0 00 00 7E 46 00 0D 03 00 01 F7. now if i PING with F0 00 00 7E 46 01 0F F7 i receive the same sysex string back, so i assume that the slave is setted up properly
  3. i removed the optocoupler from the slave
  4. connected the master with the slave: master VS pin of J11 goes to the same VS J11 pin of the slave.
master M0 pin of J11 goes to M1 J11 pin of the slave.
i checked with the tester the connection of the pin TX of the master and the RX pin of the slave and they are connected (directly on the PIC IC)
  1. both sids receives on the same midi channel
the result: i get only NOISE from the slave SID, while the master SID is correcly working…
any ideas?!?!
i’m at a little step to the conclusion!!!
Did you push the Link button?
-> see also http://www.ucapps.de/midibox_sid_csB.html
NO!!! ;D
yesterday evening was very busy and exciting… because finally my sids worked and i setted in hurry up all the connections to build the master/slave chain that i forgot this “little” point! :slight_smile:
thanks again!!
now my SID unit is working perfectly!
i need only to make all the proper connections in a convenient way and place all inside the case!! :slight_smile:
