Hi there,
This is my first post on this forum. I generally don’t like to post as I try to find the answer to my problem in previously discussed issues…but I’m stuck.
I am building- well nearly finished- my first project. It is a live controller for Native Instruments B4. I’ve essentially tried to keep it as true to ancient specs as possible eg, refurbised old drawbars fron a Vox Super Continental, built it into an old valve radio casing with french polish veneer, using chicken neck knobs on the pots, and ultimately, no digital buttons.
My conundrum however is such. I have nine drawbars with which to control the NI B4 drawbars. Is there a way that I can add a switch to toggle the function of these between thae upper and lower manual, through use of an AIN switch.
I know that if it can be done it would be a question of a boolean operator in the code checking the status of this switch being either a value of 0 or 127 ie. repalcing a pot with a toggle switch.
I have not the need for a DIN thus far, and as I am near completion, do not want to have to put one in. I know this forum is immensly busy with all us newbie questions, so I’m just going to finish the project and leave a spare button till somone gets round to me.
Before I go…Thank you all for what I consider to be the most valuable resource on the world wide web ![]()
MP
