Cables
Does somebody know which kiend of wires is suitable for the midi box, Im talking about the cables inside, from teh board to the por, fader, power, etc…
I dont really know what to get…   ???
thanx again , 8)
Hi
Ribbon cable is good for most things as its very flexible and fits in to small gaps in your case.
or coloured hook-up wire
doent really matter as it low current and voltage
Use sheilded cable if your gonna run cables over a distance
I agree, Ribbon cables (20 poles or so) are really good. you can always put 2 wires to one (so you have 10 signal ways). This way you can use those “Pfostensteckverbinder” (German word -> english?? Ribbon connectors??). Fast and secure way.
btw: long distance means over at least 1 meter. So nearly never in a case (also the case is shielded good against exterior disturbances, so you can count with 1 1/2 at least).
