Hello all,
In my quest to work my way up to building an MB6582, I have been sourcing SID chips and an old C64 to yank some parts from. I just got one of the two SID 6581s that I bought off eBay in the mail, along with an old C64 that also has a 6581 inside.
I was hoping to use the C64 to test any SID chips that I buy. However, the C64 doesn’t seem to make any sound. I hooked it up to my Mac with an Elgato EyeTV adapter, and I get video, but no sound. I know that sound is coming through the EyeTV since if I pull out the cable I get static noise with the fuzzy TV signal, and when the cable is connected I can touch the screw terminals on the RF adapter for the C64 and hear static hum as well while the video picture slightly distorts. I tried to make the C64 make some noise by typing in the BASIC sound program in the C64 manual, but it doesn’t make any noise at all. I cracked open the case and there is definitely a SID chip in there alright, it just seems to be quiet. The motherboard was covered in dust, so this thing has obviously been around a while.
So, here are my questions for you guys.
- Is it likely that the SID chip is just dead? I looked around a bit on the web and it seems like 6581s are more susceptible to untimely death than 6582s. Is there any way to test the SID chip while the C64 is powered on besides handing BASIC programs to it? I have a logic probe and a multimeter, although I’m a relative beginner with electronics so please be gentle with any suggestions. Any other suggestions for checking the chip in situ?
I have another SID chip that is supposed to work that I could plug in to the socket in the C64, but two things are preventing me from wanting to do so.
The first that worries me is that the power supply I received with the C64 describes itself as “5VDC 7.5VA” and “9VAC 9.0VA”, but I’ve read on the forums that the 6581 is supposed to take 12VDC. I’m not really sure how to interpret the label on the power supply - is it the correct one?
The second thing that worries me about testing my other SIDs in this C64 is that if the one in the case is dead, I’m scared that maybe a malfunction in the C64 itself killed it. FWIW, everything else seems to be working. Should I be worried at all about putting my other SID chips in on this board?
If the answer is to yank the existing SID from the C64 and try the other one, any tips on the best way to yank the old chip out and put the new one in without damaging anything would be appreciated. It looks like you just pull it out gently with pliers, but I figured I’d ask the experts first. Many thanks in advance for any help you guys can offer me!
Cheers,
- max
