I don’t know if it would be of interest to anyone. But I found C64 supplies for ~5.00 USD. I think there is a minimum order with them though. It would probably have to be a group buy.
EDIT: I bit the bullet and contacted the guy. Ill post what comes of it.
If my memory serves, these are later C64C supplies. I don’t think there are 2 9vac supplies in them. I’ll research it a bit more. Regardless, they would work beautifully with our midiboxen. I need to start a tally to get a pricing. I must state this though, I HAVE NO INTEREST IN HANDLING A GROUP BUY. They want a firm quantity before they set any pricing.
the description implies two 9vac sections:
RECOTON 9VAC/9VA & 9VAC/9VA & 5VDC/8.5W SET TOP POWER SUPPLY
better not to waste an unused 9vac section.
or do you want to destroy the earth? *whack*
(it’s a joke, stryd, see the *whack*?)
i’m confused, why do you need a tally if you have no interest in a group buy?
Recoton Model C-1004 is a verified C64 supply. 9VAC+5VCD only. I don’t care what they listed, I’m going by other specs. I had one of these on one of my 64’s a long time ago.
And forget the tally. I let my curiosity get the better of me. If someone does decide to do a group buy and the price is good, Id be in for at least 5 myself.
Since I don’t have a power supply for my MB-6582 yet, I am very interested in this, assuming it is indeed the correct power supply. I contacted the guy and asked for a quote on 100 of them…
I suggest Doug proceed with arranging a bulk order, instead of everyone annoying this guy with quotes for one.
Even with this recommendation for the C-1004, it’s best to check one before buying a lot. “Terminated in DIN type plug” sounds promising though and if I was in the U.S. I’d buy one to check… unfortunately they are no good to me here in Australia with 240V mains, even after swapping the power plug ;D
9VAC/6.7W & 5VDC/7.5W. Commodore 310157-02. UL/CSA. Black set top supply. $5.50 Ea/130, $7.50 Ea/10. 113 in stock CS017 Contact ted, the specialist for this product
this will be interesting if this PS are quite new, mine, all very used, burn the fuse many times, and i’m shure, i’ve not shorts contacts on my board.. 8)
I’ve gotten the preliminary info back on these power supplies, and I think it will probably be worth doing a bulk order. I am requesting more info about them - are they individually packaged or in bulk, what will the actual shipping cost be, etc. I’m also trying to get a sample from them to make sure it’s what we need.
OK, I’m still waiting for the final info, but I wanted to let you guys know that I have a sample on the way to make sure it’s the one we need - I should have it next week. Looks like these things are going to be about $4 each plus whatever shipping will be…
I may be in for 2 but we still need the female DIN receptacle that seems to be available only in the c64s so I thought about replacing both male/female connectors with this:
Doug, would you organize a bulk buy for some of this connectors too?, or something less expensive if anyone finds some, this ones will cost about the same as the psu
Alright, the other info I asked for has arrived. Are you sitting down? Shipping for 100 supplies is $320!
That means each supply with cost $7.20 plus shipping. I think I can use Priority Mail, so that will be $8.95, and that will cover shipping for more than one supply.
I’ve set up a wiki page for the bulk order. If you’re interested in joining this group buy, go to:
Hey Wilba. Should people that didn’t get a MB 6582 pcb on the first run even look at this? I am just wondering if this will still be a needed part in addtion to smash’s base board kit? Or is some kind of power supply going to be included in the kits already?
