C64 case design
I’m not sure where to post this so I’ll put it here; Maybe someone is interested using similar design when building a quad MBSID.. I won’t go into specific construction details here since I’m planning to write a blog out of the whole project as soon as I have the time for it. Details/problems/etc of the whole project are logged but need to be given html-layout etc.
Anyway.. Put short my idea was to use TK’s design but combine it with recycling as much of the existing C64 hardware as possible. I’m sure the main design concept(s) will become apparent when you check out the pics ;). Go here: http://www.kewlers.scene.org/bitchard/quadsid/.
Ta,
.Arto.
Very good looking :D.
How did you do the lettering on the frontpanel?
Hi Arto,
very clean work!
Do you allow me to bring the pictures into the gallery, and to introduce your box in the MIDIbox of the Week section? :slight_smile:
Best Regards, Thorsten-.
Nice idea using the keyboard bracket to mount the front panel knobs and stuff. Good work.
They were handdrawn with paint pens.
Yeah sure, although I’ll propably try to get some better shots a bit later (some of the current ones are a bit blurry since I took them in a hurry).
.Arto.
Very neat job indeed!
Did you make the panel yourself?
Nice display… is that plexi cut down to size?
Where did you get the display? It’s so clear!
