C wrapper and switch/led matrix...
Well, I make some mods in the C wrapper to support the switch matrix stuff, but with sm_simple.inc and sm_fast.inc I get always the same probleme : when I press a switch, it can’t stop toggle between on and off… don’t know why, it works with the example app (so it’s not a hardware problem).
I want to use the same dout for driving switch and led matrix (led matrix not yet solder). Maybe it would be a better idea to make those change in mios?
I want to use encoder too… so I think there I can’t use sm_fast.inc?
Thanks! :wink:
Pilo
Hi Pilo,
well, what should I say to this statement? I don’t know your code :wink:
no, because matrices are always very hardware dependent and require customizations which are better located in the application, because parametrized code would be too slow.
MIOS already provides a hook which allows to prepare the DOUTs before they are updated. However, currently it is not possible to use this hook in C… I know… this will be added to the C wrapper once I find the time.
you can use two seperate DIN/DOUT chains, one for the standard MIOS stuff, one for the button matrix stuff. You only need to change the pinning in sm_fast.inc
This would be the most performant solution
Thanks for the answer :wink:
Actually I add stuff in mios_wrapper.asm file :
USER_Tick
        extern  _Tick
        call    SM_ButtonHandler
        lfsr    FSR0, STACK_HEAD        ;; initialize stack
        lfsr    FSR2, STACK_HEAD
        goto    _Tick
USER_SR_Service_Prepare
        ;; TODO
        ;; not forwarded to C yet -- no problem at all, but some additional
        ;; SFRs needs to be saved.
        call    SM_PrepareCol
        return
USER_SR_Service_Finish
        ;; TODO
        call    SM_GetRow
        return
I try to customise to make the matrix works… I need to check again maybe my error is stupid :wink:
ok, so lets assume that it is a stupid error - maybe the reister addresses declared in app_defines.inc are overlapping the C variables?
You can check this in the projects.map file, where all addresses are listed.
