Total newbie here.
Looking for recomended reading.
Used to write in basic(don’t laugh)
Thanks
Brett
Total newbie here.
Thanks
Brett
I googled “introduction to c programming” and this was the first
hit:
http://www.le.ac.uk/cc/tutorials/c/
If you’ve programmed before just about anything should give you
an overview of the language, it’s syntax, datatypes, etc. After
reviewing such material download the MIOS c skeleton and start
working through it referring back to the reference material as you
try to understand what you’re reading. Get the ‘build enviroment’
set up and try to build the c skeleton without any changes. See
if you can load it into the core. Then try and write something to
the LCD. Just stick with it… taking small steps. If you’ve
programmed before the basics of c will come quickly. MIOS doesn’t
require the esoteric stuff.
Welcome aboard ![]()
Hey if you find any links that you find you use a lot, please let us know.
Don’t knock BASIC man! GW BASIC and 8088 ASM were my first ever programming languages hehehe Seriously though, programming languages are never all that different. You’ll find that once you forget about using line numbers to refer to things, you’ll be set, and you will be able to apply similar concepts to your C code.
So what have you got planned? ![]()
I am going to start off with a midiboxLC . I know it isn’t for beginners , but I have a bit of electronic experience . And I have not been happy with what is being offered . Eventually i want to develop automation for consoles .
The journey begins.
Brett
Thanks guys!
One last question…Any reccomendations for a C compiler for Mac OSX.
Brett
Search the forum and/or read the wiki. You’ll find what you’re after.
HINT: One topic above this one, stickied… how’d you miss that?
I saw it after my last post…DOH
Brett
ehhehehehe ![]()
