Buttons Values - Min /Max / On /Off
I was wondering how to implement custom MIDI CC values for the ‘off’ value of a button, with serge’s virtual midibox app,
at the moment i can only see a way for programming midi CC values the ‘on’ state, as the ‘off’ value defualts to 0 and there doesnt seem to be an obvious way to change this to another value
ideally i would like to be able to program two values for each button, and each button could have a different pair of values.
here’s an example -  using the toggle function i would like to jump between two distinctive filter cutoff values - ‘on’ = 99 and ‘off’ = ‘23’
can this be done in vmidibox.exe ? or do i have to go another route?
cheers
D
Which app? I’ll take a look at the source…
midibox64.exe - that would be Serge’s editor,
otherwise would we have to get into hacking the MIOS version dierctly?
I mean which MIOS App… I’m not sure if the app supports it, so I was going to look at the source…
just to prevent misunderstandings: :wink:
midibox64 = mios application =  ;D
Okey Doke I’m gonna go play “figure out what TK did in here”…Lord knows why I felt like doing this for my own entertainment!  ;D
Short answer no go
Long answer you’d have to implement the minimum feature, currently it toggles between your value and zero… It’d be a global change unless you made changes to the DB, which wouldnt be too mega hard, but not so easy either. But it occurred to me, why not set the minimum on the synth? For eg:
increase cutoff on the synth to 23 and use:
‘on’ = 76 and ‘off’ = ‘0’
:wink:
Edit: I never looked at the MB64(e) and I’ve gotta say I’m very impressed! I had no idea it had so many cool features :slight_smile:
Edit2: oh yeh…interesting bits (I looked these up, forgot to post them, then closed them, doh)
mb64_midi.inc line 337
mb64_buttons line 246
Another way you could do it is set the value to match the value of a certain pot, so for example:
Button1=120
Button2=70
Button3=90
Button4=20
You could make it so that they all reference Button1 as a minimum (instead of zero) so the max of each button is as you set it, but the min is always whatever you set button 1 to… or you could have many minimums by using neighbouring buttons values eg:
Button1 On=120
Button1 Off=70
Button2 On=70
Button2 Off=90
Button3 On=90
Button3 Off=20
and so on…
You could do this by jumping through the table and getting the value of the next button and setting that instead of 0…
You can implement different button values with meta events (-> mb64_meta.inc, mb64e_meta.inc)
Well shut my mouth! Sorry for the bad info!
:slight_smile: great - as soon as i get the OS up and running i will experiment with it and report back!
thanks guys.
Ah I see now… I ignored the branches to SFB and meta handlers because I thought that they were internal functions only, which goes to show that it’s a good idea to actually use a device before you try and figure out what it’s sourcecode does (I’ve never even seen an MB64 heh)…and it also proves once again that assumption is the mother of all f*ckups ;D
Edit:
Check out mb64_meta.inc, look for MB64_META_Handler_DoubleNote for an example of how to handle different events for button in and out :slight_smile:
