Hi, we try to connect our first button matrix to the midibox lpc. We have a DIN and DOUT Modul connected to a button matrix. Unfortunalty, we get only an event on some buttons. Some buttons don’t show any reaction others create a lot of events. No real schema. How should we debug this.
We soldered the diodes in the wrong direction. Can we fix this with "inverted_sel=1 and inverted_row=1"
Can’t you just switch the cables between the Din and Dout boards that goes to the keys? Then the diodes will point in the right direction. Only problem might be that the keys won’t send the right command. But this can be changed.
we don’t understand this. We tried the DIN_MATRIX Command in all variants. We connected the DOUT pins to the Buttons and than to the cathode of the diode and than to the DIN Module. Our Command is
