Button Matrix or DIN?
Hello,
I found the C Example for a Button Matrix concept for MIOS. I have the same task, I need to scan at least 128 buttons (256 max) quickly with one core. Now I started wondering:
What are the advantages/disadvantages of that button matrix in comparison to using standard DINs for 128 Buttons (means 4 fully equipped DIN modules) regarding
  • speed/performance
  • accuracy (missed button presses)
  • memory usage (on the same PIC, I want to do some I2C communication as well, if possible)
I looked around in the forums and in the wiki, but did not find much… There is the 16x16 matrix that QBAS developed, but I did not find a comparison to the old system of using chained DINs.
Thanks, ALEXander.
Thanks!
ALEXander.
  • speed/performance
Fast enough :slight_smile: You can change the update speed so it’s up to you.
Only if you press them really fast! See above.
A slight increase but nothing that should stop the rest of your app from fitting.
Go with the matrix.
Well, on second thoughts I think I will go with the “normal” solution nevertheless, because i can modularize it better.
With the normal input solution, i can put one or two 74hc165 on one pcb, together with buttons and leds, and interconnect them with just a couple of wires. for the matrix, I would need more wires.
Best, ALEXander.
