button configuration
I’m building some application for an interaction project at my university. I want to use the midibox64 configuration, but don’t want to use the menu, page and other option because I don’t have an LCD.
With mk_sys I’ve configured the pots, but how do I configure to DIN’s to send a note on. In the midibox64.ini file, is written that I should disable the buttons in the asm file. How can I do that ?
I’ve looked in different files, but it’s not exactly clear to me how everyting is organised.
Also the question how I can let a led ( on the DOUT ) burn on ( for 500ms or something ) :
  • an incoming sysex string
  • if a specific DIN is triggered and it should stop burning if I trigger another DIN
I don’t have I clue how to do someting like this ( change the asm file ? )
Thank you in advance.
Hi Kapser,
in order to disable the menu navigation buttons, you have to modify the numbers behind “#define DEFAULT_DIN_MENU_*” to > 64, e.g.
#if DEFAULT_ENC_DATAWHEEL == -1
 #define DEFAULT_DIN_MENU_EXEC         64
 #define DEFAULT_DIN_MENU_RIGHT        65
 #define DEFAULT_DIN_MENU_LEFT         66
 #define DEFAULT_DIN_MENU_SNAPSHOT     67
#else
For your special functions you need to program some additional code (and it isn’t that easy if you haven’t worked with PIC assembler yet)
