Button behaviours
Hi all
I read somewhere in this forum that @ononly behaviour is “like a one-shot”, does this mean that when pressed it turns off by itself after a certain time?
If a led (via dinout) is used to indicate the state of the button, would it also turn off after a certain time?
I fully understand @onoff and @toggle behaviours but @ononly???
Also: If a latched switch is used rather than a momentary switch, so that once pressed that Dinx4 input in held at logic 0, does the software consider it to be pressed only one time, or does it consider it is a new press on each serial scan?  In other words what is the end effect of keeping a finger on a button?
Hope this makes sense folks
Regards.
