Hey
This idea is probably very stupid and very expensive…
I want to build my own SSL Console.
I wanted to have a console like this for years, but with a starting price of around 50.000€ even the cheapest one is still way too expensive for me.
I’m not building an audio mixing console, I’m building a DAW controller with the layout of the current ORIGIN console.
Luckily most of the legendary SSL hardware components are available as plugins.
I think and hope the MIDIbox modules and software should be the answer to all my problems, but I hope and would kindly ask for help and or improvements on my design and use of the components.
1. Design
My friend Ole and me startet the design in Adobe inDesign.
He works as a graphic designer and pretty much knows his way around all the adobe design software so we startet working.
For the layout we take the ORIGIN console as an example.
Therefore the controller should consist of 32 channels, 16 on each side, a mastering section and a Bus section.
We nee to change some parts in the layout because we don’t need all the routing possibilities, because it’s just a controller not an analog console.
Working with the real measurements of an SSL I found on the website of https://www.recycledaudio.co.uk and inspired by pictures of the ORIGIN we came up with this design.
Every channel has a motorized 100mm fader with 3 buttons for solo, cut and arm and a Pan knob at the bottom.
Above that is the EQ unit and above that 8 free programmable knobs mainly for busses. At the top is a Gain knob and a mono button.
Working with a DAW controller all my stereo channels still are routed to one channel inside the DAW. Therefore I can’t split a stereo channel on two channels and the mono button will help differentiate between mono and stereo channels.
I am currently working on a MacBook Pro. Because of this I need some space in the mastering section for my laptop to sit.
I will build this section modular, so I can change the plate where the laptop sits to another one where a keyboard and a trackpad could sit, if I choose to work on a desktop PC in the future.
The. Laptop will sit on a grid with fans below. This way I hope I don’t have to run the fans of the MacBook as high, because they are quite noisy.
Next to the MacBook is the transport section with some basic control knobs and buttons.
Above the laptop is the bus fader section, consisting of 8 60mm Faders and Solo and Cut buttons.
The whole front panel of the console will be made out of 3 mm thick metal.
All the holes and cuts for the hardware will be cut by a laser cutting firm.
Adobe Illustrator can export DXF files with which the firm can work.
Last but not least on top of the console will be a meter bridge.
The meter bridge will be build out of 7“ LCD monitors and merged to one big screen with an 10 times HDMI splitter like this one:
https://kvm-switch.de/de/VS0110HA.html
I will post the next part in the next days, talking about the hardware components and the midibox modules.
This is going to be a very hard to build project, but I think also a lot of fun!
Thanks for sticking around after that long text!
Frederik / M e a d o w
[SSL Laser Vorbereitung.pdf](< base_url >/applications/core/interface/file/attachment.php?id=15475)[SSL Design Oberfläche ganz (Ohne Schrift).pdf](< base_url >/applications/core/interface/file/attachment.php?id=15476)
