I built my MB-6582 last year, so relatively recently…
In the process I pieced together a few handy references that helped me with my build…
Good luck with yours…
Planning the cost of a build, based on various component options:
< base_url >/topic/21537-cost-of-building-a-mb-6582-today-with-either-premium-or-economic-components/?do=embed&comment=187610&embedComment=187610&embedDo=findComment
PCB Sets are still available here:
https://modularaddict.com/shop-by-brand/midibox-ucapps-de
Nice pre-made Aluminum panel sets available here:
http://thebeast.co.uk/?product_cat=midibox
As a bargain basement alternative to aluminum, you could have panels fabricated as if they were PCBs, which saves a ton:
< base_url >/topic/21320-mb-6582-panel-check/?do=embed&comment=188548&embedComment=188548&embedDo=findComment
If real SIDs are too difficult to find and/or too expensive, take a look at the best clone options:
< base_url >/topic/21331-sid-clones-listsourcesexperiences/?do=embed&comment=189129&embedComment=189129&embedDo=findComment
How to program your Microcontrollers:
< base_url >/topic/18680-solved-debugging-my-mb-6582-part-2-software-upload-issue/?do=embed&comment=186262&embedComment=186262&embedDo=findComment
…Or just buy some pre-programmed chips:
< base_url >/topic/21079-pre-programmed-pic-18f4685-for-sale/?do=embed&comment=188306&embedComment=188306&embedDo=findComment
Where to get the “Just Right” power switch:
< base_url >/topic/21375-new-supplies-of-c64-power-switches-on-ebay/?do=embed
Which SID filter capacitors to use:
A useful voltage testing guide:
<___base_url___>/gallery/image/3676-08jpeg/?do=embed
There are many power supply options available, but this one is by far the easiest:
< base_url >/topic/20376-one-mb-6582-one-power-supply-a-tutorial/?do=embed
THE definitive guide for making the control surface:
< base_url >/topic/14564-building-the-mb-6582-control-surface-photo-tutorial/?do=embed
A nice little PCB that simplifies Char LCD Wiring:
< base_url >/topic/20525-16pin-sil-to-16pin-dil-adapter/?do=embed
A useful way to join the boards together:
< base_url >/topic/21498-connecting-mb-6582-pcbs-with-jst-xh/?do=embed&comment=187459&embedComment=187459&embedDo=findComment
Optional Encoder Backlighting:
< base_url >/topic/21463-rotary-encoder-backlighting-made-easy/?do=embed&comment=187704&embedComment=187704&embedDo=findComment
