So today i’ve succesfully burned the bootstraploader in my 18F4685’s. First i did some initial tests with the old 18F452. Succesfully did a hex read out from the 18F452 so the burner is working properly.
Sidenote: I’m using the P18 software from www.sprut.de which is a good and easy program but…if you have to burn more than one pic you have to close the program after you succesfully burned one pic. For the next pic, close and reopen P18. Otherwise it won’t succesfully burn the next chip.
Required steps for a proper ID initialization:
o ensure that the MIOS bootloader has already been programmed into
the PIC. You should see an upload request after power-on
(see also: http://www.ucapps.de/howto_debug_midi.html)
o upload the most recent MIOS version like described under:
http://www.ucapps.de/mios_bootstrap.html
[/code]
DenDer, again good spot on the obsolete page: "Same procedure as last year, Ms. Sophie" ;)
Ms. Sophie is a character in Lauri Wylie’s “Dinner For One” from the 1920s. http://en.wikipedia.org/wiki/Dinner_for_One. If you haven’t seen it watch it right now - there’s an awesome version with Freddie Frinton from '63:
