Hello everybody, this is my first post, and i want to salute everybody.
I am here reading for months, and looking the projects made by others. I am building an LC and i have some questions.
I am doing one like the Axel’s one, Axel in his design, use one 2 x 20 LCD for 4 channels. I want use 2 x 40 LCD like the D2K ones (because is 2 x 40, right?).
The 2 x 40 LCD that i found is 154mm Width. With this width i can cover the eight channels, if each channel is 20mm 20 x 80 = 160mm. The lcd is a bit short, but i see on other pics, that other users, uses an lcd a little bit longer than 4 channels, and uses 2 2 x 40 lcd for the eight channels. Like this.
I am right? This LC is using 2 2x40 lcd?
Any one can post dimensions from his screen? And the width of the channels separation?
Im a little confused. Thank you.
EDIT
Lorcan wrote few months ago.
Make sure you use 2 2x40 lcds to see everything, and align the faders with the channel names.
Ok, i understand the better configuration is 2 2x40.
How i can align the faders with the channel names? Do you refer that i need align the lcd in the code?
I still dont know how is the better width separation for each channel, for two 2x40 LCD.
LCD = 154 mm / 4 channels = 38.5 mm separation
4 cm fader separation for cover the whole LCD. Its a lot, and i don’t see this separation on other LC boxes.
Anyone can show me the light please.
