Build Midibox LC ?
As a beginner, should i try to build a LC ?
Or should i stick to a 64?
I want to control ableton.
Motorfaders would be sweet. :smiley:
Dear Benjamin
We can t decide for you!
Usually people build their own MIDI controller cause they want to have their own design.
The best advice i can give you is:
build a CORE with a DIN and a DOUT, hook up some buttons and leds, then load MB64, MB64E, MBLC, maybe a C skeleton and make your own app, pretty soon you ll figure out what suites best your needs
Simone
Thanks, I did not know things could be this changeable.
…I did not know…
That only leaves you with one option: Go read! Now. Go do it ;D
ok i think i just found one
Yes, as a beginner you can make a midibox that has pots, motorfaders, encoders, LCDs, LEDs, joysticks, logic control, etc. You just need to be willing to read, learn, try, fail, read, learn, try again and spend lots of time and cash - being a little crazy helps. Everything will be just fine.
LOL!
No, it doesn’t help … it’s a MUST !!
Greets
Doc
i just found the thread i had overlooked            http://www.midibox.org/forum/index.php/topic,3650.0.html
from seppoman
"Build the core module and connect the LCD - after some soldering practice this should be possible in max. one week of your schedule. So after some weeks you can get the first feelings of success and start exploring what is possible and what is needed. This is the real fun Smiley
Just try not to think about too many things at once and everything will clear up with time. Perhaps Thorsten should put a “don´t panic” sign on the home page like on the cover of Hitchhiker´s Guide to the Galaxy Wink"
Hello Bejamin!
Did you read everything here: Ucapps?
There is soo much information available, and many times stuff just keeps bluring up.
Personally i miss vital information all the time.
Either way, if you check through this page, you’ll see how modular the Mb64 is.
example 1 micro
example 2 mega
Knowledge is power, and as stated above..being crazy is a must!  8)
example 2 mega
So lets say i want to add a bunch of faders or even more leds or some joysticks or a toaster oven to this config?
Is that where i get into adding another core?
It`s not just core. And you cannot add a bunch of faders in LC. You can have just 8. You are missing some basic knowledge about MBHP, so it is better start reading or people will simply start ignoring these kind of questions.
Ok no more questions
Hehe, that’s not the point - you are more than welcome to ask questions, just try to find the answer yourself before you post :wink:
