BrennerNG weird error reports
hi all
Im using BrennerNG44 to burn pic16f48a.
Using Brenner, I get these results:-
PIC16F84 in database:
  Vpp : 13V  (12 .. 14V)
CP-Blocksize : 0800
Panelgröße : 0000
HEX-file-name : picF84a_test.HEX
– HEX-file loaded
– 1 k FLASH needed
– 0 Byte EEPROM needed
– HEX-file contains Config-data
Chip erased
Start to program Flash
##–>7 errors in PROGRAM      ************* note
Start to program ID
– no ID to burn
– ID o.k.
Start write Configuration
##–>1 errors in Config    ************* note
– finished
config used:
        __CONFIG _CP_OFF & _XT_OSC & _PWRTE_ON & _WDT_OFF
include used: “P16F84A.INC”
** Ref notes:
Does anyone know why Brenner detects program errors and config error when MPLAB asm says all is fine?
Cheers everyone
Hello,
I was having the same problem trying to program a 16f84a…
I was getting about 22 errors in program and one error in config…fortunately, I already knew that the code wasn’t the problem, cause I’ve used it before and successfuly burned the pic…
It turned out to be a hardware problem…I had a faulty transistor(bc337) that was not shutting Vpp off, so, no matter what code I would use, I would allways get the same errors!
here is a link to the thread that described this symptoms
http://www.midibox.org/forum/index.php/topic,14111.0.html
after replacing the transistor everything went perfectly!
So my advice is:
-Make sure that you’re passing all hardware tests;
-In order to help you debug your burner module follow this thread:
http://www.midibox.org/forum/index.php/topic,14114.0.html
Good luck!
thanks for the reply analogue_mo
stupid as it might sound, i had not provided power and the leds seemed to say all was well, but thanks anyway mate.
