Bournes Encoder Skipping... Checked Wiki
Ok only trouble I am having with my Stereo Sid is that the main menu encoder is skipping which is frustrating… I searched the wiki and found this http://www.midibox.org/dokuwiki/fix_for_skipping_encoders?s=ec12
I make the the change to the 6581.asm file but when I compile the code I get a syntax error [105]… I get the error when I add the recommended code… When I remove the code no syntax error… I am adding the code here… But the wiki shows the code being added after a clock divider statement which I do not have in my code… I know this is an easy fix or do I have to physically have to remove the Bournes encoder and remove the pin?
Thanks..
#define DEFAULT_ACCENT_OSC3_R_OUT 0
;; sets the default display mode for the LED matrix
;;    0: shows modulation assignments after power-on
;;    1: shows modulation meters after power-on
;; the mode can be toggled by pressing two mod target buttons at the same time (e.g. O1 and O2 Pitch)
#define DEFAULT_LEDMATRIX_MODE 0
;; if != 0, special variations for MB6582 hardware will be selected
#define DEFAULT_MB6582_CS 0
org 0x3082 ; never change the origin!
------>This where I am adding the code #define MIOS_ENC_MODE_DETENTED3 0×82
;  In this table all button functions are mapped to the DIN pins
;  The function name can be found on the left, the shift register and pin
;  number on the right side.
;  SR/pin numbers:
;    SR =  1 for the first DIN shift register
;    SR =  2 for the second DIN shift register
;    SR = 16 for the last DIN shift register
;    Pin = 0 for the D0 input pin of the shift register
Hi!
are you using V2 of the SID firmware? In that case it’s slightly different from what’s described on the wiki I think. The code I downloaded from www.ucapps.de already had a line in it for the detention mode. It looked like this (just search on these lines in the editor…):
ENC_ENTRY  1,  0,  MIOS_ENC_MODE_DETENTED2 ; menu encoder
For the bourns encoder I changed it to
ENC_ENTRY  1,  0,  MIOS_ENC_MODE_DETENTED3 ; menu encoder
which works perfectly for me!
Rutger
No dice I try’d that and no change maybe I have a flaky encoder… I have few spares from when I changed the encoders on my Yamaha A4000 now to figure out which one’s on it that were flaky…
