Hello,
First of all congratulations for MIOS32, I have been using it for a while as my projects hardware abstraction layer for a while.
Recently I have been trying to develop an USB bootloader.
After looking at the one used by this project I’m convinced its a nice solution but I have some doubts about its functioning.
Please comment if this is how it works:
I understand that you build the bootloader and then use a pearl script to generate an array with its contents.
Bootloader is built with:Flash Origin=0x08000000 and Lenght=16K.
Then you had the file with the array (on the makefile?? Is it how you do it?) to the main application and built it with a linker file having the “mios32_bsl” section defined first.
But, where do you relocate the vector table? I don’t see any “NVIC_SetVectorTable”
Sorry if this isn’t directly connected to your project, but I would appreciate any help
