I have a 16x16 matrix that I need to control. I am using this to add a midi output to an old organ. It
has one magnetic reed switch at each point.
I believe the inputs work with 2 DOUTs and 2 DINs. For the sake of this post, I will assume the DOUTs
are on the side and the DINs are on the bottom. In return for a button press in the matrix, you get a
pin number and a value. Is the pin number counted left-to-right and then top-to-bottom in the matrix.
Also, does the value return 1 for pushed and 0 for released or 0 for pushed and 1 for released?
Finally, how do I specify what part of the matrix is connected to what DOUT or DIN
Is any of this even close to correct, or am I way off base?
