BLM Driver with 8 columns??
Hi all,
Does somebody knows if its possible to change the Blm driver to drive a 16*8 (16 rows and 8 columns) button/led matrix instead a 16*4 button/led matrix ??
I tried to change the blm.inc but my assambler skills are very less.
I think I have to change some in this part of blm.inc to drive all 8 SR outputs as cathode (columns).
_BLM_PrepareCol ; (for C)
BLM_PrepareCol
	;; increment column
	SET_BSR	blm_selected_column
	incf	blm_selected_column, F, BANKED
	bcf	blm_selected_column, 2, BANKED	; wrap at 4 <--- when im change the 2 into 0, 1 or 3 the voltage on the cathode outputs changes. WHY? What does this line??
	;; select next DOUT/DIN column
	movf	blm_selected_column, W, BANKED	; (* see note below)
	call	MIOS_HLP_GetBitANDMask	; (inverted 1 of 8 code)
	andlw	0x0f <--- Is this the matrix lenght. In this case 16 ???
	movwf	MIOS_PARAMETER1
	;; duplicate the 4 selection lines for button matrix <----- I want to cycle 8 Outputs instead 4 duplicated outputs
   swapf	WREG, W
   iorwf	MIOS_PARAMETER1, W
	;; finally apply inversion mask (required when sink drivers are connected to cathode lines)
	xorlw	BLM_CATHODES_INV_MASK
	;; output on CATHODES* registers
#if BLM_DOUT_CATHODES1
	movlw	BLM_DOUT_CATHODES1 - 1
	call	MIOS_DOUT_SRSet
#endif
#if BLM_DOUT_CATHODES2
	movlw	BLM_DOUT_CATHODES2 - 1
#endif
	;; store row*2 offset in IRQ_TMP1 to simplify the addressing of blm_row_green and blm_row_red array <--- Could somebody explain??
	rlf	WREG, W
	andlw	0x06
	movwf	IRQ_TMP1
Could somebody help me??
PS: sorry for my less english skills. I hope you can understand what im mean.
DUsentrieb
BLM_PrepareCol
;; increment column
bcf blm_selected_column, 3, BANKED ; wrap at 8
#endif
#endif
rlf WREG, W
andlw 0x0e
movwf IRQ_TMP1
[/code]
You also have to adjust the array sizes:
[code]
#if \_BLM\_NO\_DEBOUNCING == 0
\_blm\_button\_debounce\_delay res 1
blm\_button\_debounce\_ctr res 128
#endif
blm\_selected\_column res 1
blm\_button\_column\_ctr res 1
blm\_button\_row\_values res 16
blm\_button\_row\_changed res 16
\_blm\_row\_green res 16
\_blm\_row\_red res 16
If assembler looks like voodoo for you, just have a look into the appr. MIOS32 implementations:
BLM:
http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fmodules%2Fblm%2F
and a more generic BLM driver provided by This (it also supports your 16x8 configuration):
http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fmodules%2Fblm_x%2F
The upcoming BLM_SCALAR firmware (for PIC and STM32) will provide 16x8 and 16x16 duo LEDs. So, if you don’t manage to adapt the current BLM driver, just wait for the updates.
BLM_PrepareCol
;; increment column
#endif
#endif
rlf WREG, W
andlw 0x0e
movwf IRQ_TMP1
#if _BLM_NO_DEBOUNCING == 0
_blm_button_debounce_delay res 1
blm_button_debounce_ctr res 128
#endif
blm_selected_column res 1
blm_button_column_ctr res 1
blm_button_row_values res 16
blm_button_row_changed res 16
_blm_row_green res 16
_blm_row_red res 16
BLM:
Thank you for your quick answere Thorsten.
I have tested it with a 8*8 matrix and its work fine.
You are my hero.
and thanks for you awesome Midiboxproject.
“I love Midiboxing!!”
dUsentrieb
