Hi all
I have a question about blinkig LEDs with some interval.
I can’t find where is place in main.asm for make it this.
I thing that mabye is in USER_Timer but I dont know how to do it.
Have you any ideas? ![]()
Thanks for reply
Best Regards
LX
Hi all
Thanks for reply
Best Regards
LX
ask MTE. He had to implement some blinking led in his box too. But I dont know if he found a way to do, cause the only command which can be used is MIOS_Delay (sais MTE… don’t know if theres another cmd) what delays all operation and not just one dout.
Does it have to be softwareside blinking ? If not, you can build a blinking led with a little timer ic. nothing big. Search google.
greetz
Hi
if you want the timer to do this
*first step is to initialise the timer, call MIOS_TIMER_Init
(see http://www.ucapps.de/mios_fun.html for more info on how to use this function)
*next put your blink code in USER_Timer
do you have experience with assembler coding?
otherwise it would be easier to do this in C
let me know if you need more hints
I wanted the same thing for my LEDs once, and I had idea of doing this hard way - 555 or something. It is definitly much better to do it using software if you know how, but I dont :-\ You can also try blinking LEDs, but you cant change the intervals.
Thanks you all..
I try to prog with MIOS_TIMER :![]()
I hope that I’ll be successful.. ![]()
Best regards
LX
Hi
;D !!! success !!! 8)
It’s functional…
I use timer with period about 25ms and filtering every 8th cycle. -> ideal blinking.. ![]()
I have finished flashing clips in Ableton Live and it function like the program.
I use incoming 4 mesages 7E, 7F, 01, 00 from clip. When I switching clips on PC, midibox LEDs are same like Live. ![]()
B.R. LX
Great ![]()
Im very interested in this Code…is it programmed in C or Assembler ??
do you want to share your programming ?? ![]()
Regards
MTE
me too!
please share!
in assembler… ![]()
I must tune this code, becouse i found 3 mistakes at some special combination of switching clips :-\
But it’s 1-2 days debugging ![]()
Than I’ll make video of this..and share code ;) (but it is quite secial for my Buttons module) -> only for your help ![]()
B.R. LX
cant await ;D
yay! ;D
best thing that happened today
I’m very interested too ;D
hope it’s not too complicated for me !
mission complete!!!
my code is quite complicated ???
I put there steps for easy blinking…
timer initialization - I place this to USER_Init (but,you can start or finish timer any time)
movlw 31250 & 0xff
movwf MIOS_PARAMETER1
movlw 31250 >> 8
movwf MIOS_PARAMETER2
movlw 0x03
timer jump to USER_Timer every 25ms from now 2) You must write this definition on the top of main.asm (determine count of skips then blinking routine will be perform)
#define LX_CLIPS_BLINKING_SPEED 8 ; 6=quickly 8=mediumly 10=slowly
USER_Timer -----------
USER_Timer
; This is for erase speed interval…
movf LX_BL_Clock, W
sublw LX_CLIPS_BLINKING_SPEED
skpnz
clrf LX_BL_Clock
; if LX_BL_Clock = 0 go to LX_PrePlay_BL routine…
movlw 0x01
subwf LX_BL_Clock, W
skpc
rgoto LX_PrePlay_BL
rgoto LX_Timer_End
LX_PrePlay_BL
IFCLR LX_BL_Enable, 0, rgoto LX_Timer_End
IFSET LX_BL_Switch, 0, rgoto LX_LED_PrePlay_On
LX_LED_PrePlay_Off
; >> ------------------ LED Off ------------------
movf LX_Blinking_Button, W
call MIOS_DOUT_PinSet0
bsf LX_BL_Switch, 0
rgoto LX_Timer_End
; << ------------------ LED Off ------------------
LX_LED_PrePlay_On
; >> ------------------ LED On ------------------
call MIOS_DOUT_PinSet1
bcf LX_BL_Switch, 0
; << ------------------ LED On ------------------
LX_Timer_End
incf LX_BL_Clock, F
return
registers
LX_BL_Switch - if bit D0 is 0/1=On/Off LED
LX_BL_Enable - if D0 is 0/1=disable/enable blinking
LX_Blinking_Button - into save number of button
I finish today… :-\
B.R. LX
5.3.2007 - sorry, I must edit this reply today (code was wrong) :-\
