I’m just new on this forum. But I have a plan to build a midi controller for Resolume (VJ app.). I found everything I need except for the buttons. I want large square shaped buttons like the ones on the picture except i need a 4x5 setup and not a 4x4. I can’t find a manufacturer or supplier.
Thanks for the reply. These are indeed the buttons I am searching for, the lasercutting of a frontpanel is no problem. (we have got a laser cutting machine at work, so I think that will be done for a case of beer). But fitting a button under there will be. And I need a 4x5 and this is a 4x4. And I will probly need a view of the same buttons as a single button. (sorry for my english). Doesn’t anyone no a company that makes these kind of buttons as a single button?
Can you give me a view examples of the smaller (non soft) buttons?
i found a place from one of the links on the forum , its an mpc repairers and they have got hte pads and the contact sheet that goes behind it, i have ordered a set for myself, as i intend to build a replica control of the motu bpm software, i want it to look exactly like the unit in the software i also have to find some small non motorised faders similar to the ones in the nano kontrols from korg to use in there, if i cant find any i will just buy a nano kontrol and rip it to bits, yep im mad but then all geniuses are start raving mad, ask tk… hes certifiable!!! lol!
i will put up some pics when i get mine through from the states.
this is what i want to build, obviously minus the lcd screen however i could fit another small midimon in there with some small 7 sement leds and have a mini mtc display also. hmmm, thats a plan then!
Thanks for all the replies. I know I can buy two of them, but it is not a very “clean” solution. I still need to build something under the buttons. I preffer a button that I can use “out of the box”. But there was some talking about hard, smaller (18x18) buttons. Do you have a link to a shop that sells these buttons?
Tnx, I think I will be going for the soft ones. But I bought some cheap buttons for testing and programming. When everything works I will buy some more expensive buttons.
