Hi everybody.
I have a problem with my Lcd.
It’s a 2x20 LCD from BG Micro website ( here )
Characters are display correctly but the backlight doesn’t work.
The power for the Lcd is +5V : it’s ok
I have made à EL inverter with a pot for the backlight. With -1 to -5 it doesn’t light
somebody can help me ?
SLP
May 22, 2007, 1:46pm
2
welcome to the board
I don’t know if you can dim EL-inverters. I actually don’t think so..
Are you sure that the EL-inverter has the right polarization?
thanks you.
for the polarization in my El-inverter it’s like that :
Input : +5
Ground
Output : -5
2 cables (black & white) are used for the backlight.
I tried :
B+(-5) : white
B- : black
And
B+(-5) : black
B- : white
Maybe this “reversing” broke the backlight (and I had already try with a positive voltage …) ?
Does the blacklight need more A for the power supply ?
Anybody have this cheap LCD Display ? ???
SLP
May 22, 2007, 2:26pm
4
I don’t know exactly what you want to tell me :
AFAIK, an inverter has an input (5V in your case, DC) and an output (about 120V AC).
Do you have a Datasheet for the inverter you use?
EDIT:
I’ve just recognized that you’re probably using a wrong inverter.
The inverter you use makes +5V to -5V. That won’t work.
You need a special EL-inverter because the EL-foil needs an alternating current of about 120V
to work.
This is a bit dangerous because of the high voltage, so you have to use some insulation-tape
and/or shrinking hose at the output.
sorry for my english … french :
My inverter make +5V to -5V.
The datasheet is here http://www.sub-version.net/images/negativeconversion.gif
but it is not connected like the right part. I have not made modification on the core module, just like this ugly schema.
B+ -----------(+5V)---- [Inverter]------(-5V)---------- | LCD Backlight |
B- ------------------------------------------------------ | |
SLP
May 22, 2007, 4:07pm
6
Good by EL-inverter.
I used 2 “super bright LED” connected to “B+ / B-” and it looks nice
It could be a cheap alternative to the classical backlight system.
