Hello all,
I tried the search function of the forum, but could get an answer to my questions.
What i want to make is a midi controller for a software lighting console. My questions are:
Does the DIN module send NoteOn message when i press a switch and a NoteOff when i release it?
How many switches can be pressed simultaneously?
In order for the leds in a DOUT module to work, can the application send a NoteOn message to light a led and a NoteOff to put it out?
When i move a fader or pot connected to the AIN module, i presume i will receive a NoteOn message with the value 0..127. is this correct ?
I have a feeling all the above are configurable, but i cannot understand how. The thing i will be downloading to the PIC, is this the one that configures all the above? Does it support my setup?
Finally, i do not plan to have an LCD, nor a BankStick module. Will i be able to configure things without and LCD? Will the configuration be preserved when i power off the controller and then back on?
Thank you in advance,
Dimitris.
