Hi everyone,
First let me say that getting my Sid up and kind of running (making a bit of sound anyway) has been my technical accomplishment of 2008!
I’m stuck at the bankstick stage. I have 3. The first board I built has them numbered 1, 2, and 3. Only #1 works (it now has the 128 presets in it).
I checked the connectivity and wiring numerous numerous times, switched chips around, etc. In frustration, I built a second board and wired up #4. #4 does not work either (again with checks for voltage, connectivity, shorts). The sid says “No Bankstick” when I try to switch in MidiOX. Specifically, it says
E002|B001* Ld Chn. 1
1***|<No Bankstick>
My soldering is passable enough that I think at least one out of #2, #3, and #4 should have worked just straight out of the box, and testing indicates they should all work. See pix below.
So do I need to upload something to the Core to inform it about the banksticks? Tried a lot of poking around in the code and searches but was coming up dry.
Alternatively, perhaps I misunderstood the multiple-bankstick wiring instructions but checked this many times as well. All wirings were the same for #1-#4 so can’t explain why #1 works and others don’t. On the bigger board, you can see that I just used vertical columns as “conduit wires” which the individual chips tapped into. This looks like the conduits on the wiring instructions (to me anyway).
Also, I have noise on some patches which I understand is likely due to a bum 6581 filter. I understand the filter can be turned off somehow in the code but poking around in the code and searches again didn’t give me any leads (that I could comprehend anyway).
Thanks!
