i will try to be more clear if it’s possible
i have a vectorboard with a couple of eproms
mounted on it
one is supposed to be bankstick A, the other maybe one day will become the bankstick B
to upload the presets i’m using the midibox patchmanager
with the 8580 presets i don’t have problem, the presets are already uploaded
in bankstick A, the other bankstick is like invisible when both are mounted.
i did a kind of experiment, i removed bankstick A and i tryed to upload the second presetsbank on my “i wanna be” bankstick B
this presetbank is read by the midibox patchmanager as bank C
so bank C is the source and bank B should be the destination(my second bankstick)
but when i start the upload the MBPM says the C & B are not available
so it’s like to say that the id of the second bankstick is “wrong”
if i upload the C as source and A as destination looks like working
but when both banksticks are mounted is a bit messy to read the name of the presets
it’s like a conflict beetween two bankstickA
if i try to select a bankstick from the CFG submenu from my midibox sidsynth
only A is available even if both banksticks are mounted
the connections on the bankstick board are ok, because if i move the eproms
from one socket to the other, the sid is able anyway to read them
but only when only one eprom is mounted
what i need is to find a way to “change the id” of the second bankstick
or stuff like that…
how can i do this?
is my explanation more clear now?
