I sort of found some info on this here, but it was a dead link, anyone have this backed up?
http://www.midibox.org/forum/index.php?topic=387.0
Otherwise, here’s my problem:
I have 2 external serial ports on the c64 case: 2 extenal banksticks in serial1 , and serial2.
I have the potential for 8 bankstick eeproms internal…
How to get the external ones hooked up?
I have 2 ideas:
-1- add a 3way switch to switch between serial1, serial2, and one of the internal banksticks.
pros: i have full internal storage (8 eeproms), and I can use either of the 2 external serial ports.
cons: I have to flick a switch depending on which location I want to write to, complex perhaps…
-2- remove 2 internal eeproms (for 6 total internal), address each of the external ones differently,
pros: they all work in harmony… both external serial ports can be plugged in at once.
cons: I have less internal storage… and one of my banksticks would be at a “non standard address” - Consequence of this is that I couldn’t expect to plug this nonstandardly addressed bankstick into a friends mbSID… (since its address may conflict with one of theirs)
Questions:
1.) Am I making this more difficult than it is?
2.) which option would you recommend above?
3.) do I really need 8 internal, is 6 enough?
3b.) (but having 2 differently addressed external sticks sounds like a bad idea too, in terms of “standards” would you agree?)
4.) If I were to do switching, how would you wire it? I was thinking of trying to wire just the +voltage for each chip, basically powering up only the chip I want to be active…
