As I recall when I inititially installed my bank stick it took a while to format and I think it had 64 pre programmed patches notice I said “I think”… Anyway I think I need to reformat it since I cannot save any patches to it… I go to the Save menu and all I get is the following…
E# do!
E—
I followed the guideline on the stereo sid “First steps” but am unale to save… When I scroll thru the the patches I get the default Lead Patch and all the rest are blank… Oh BTW the Stereo SID rocks… I have not been able to mess with it much since I am a stay at home dad with my 11 month old son so time is a rarity for me…
When pushing the 1st button E001 will flash with an underscore under the 2nd “0”… When I turn the encoder I get E— with an underscore under the 2nd “-”… SHould I not be able to dial in the bank# with the encoder?
right, and the described behaviour is typical when no “suitable” bankstick is found. So you probably have only one bankstick connected - for saving ensembles, you need a separate additional bankstick.
