Ok, so here’s the Idea I am having. I want a Balanced I/O board for my MB sid V2 (using the base PCB of the MB6582) but it also could be suited for other uses MBFM, MBMixer, Standalone balanced/Unbalanced converter box, etc…
I am thinking of using the SSM2142 and 2143. Why, because I already have a tube of 2142’s, also these are pin compatible with some other line drivers on the market (ones made By THAT Corp. , maybe others too). I have attached the datasheets below
So Q’s and thoughts:
Since I am already taking +/- 15V into my sid( EDIT here I am refering to the machine as a whole, not the SID module)to regulate down to +/-12V for AOUT and Seppoman’s filter module, and +9 for the 8580 sid’s I am using, should I supply the 2142/2143 with 15V? or is there no point when hooking up to the SID? of course I could leave the option for both, the chips will take up to +/-18V.
Do i need any sort of buffer between the 2143 (balanced line reciever) and the SID input? I was thinking I may need a pad or variable attenuator to deal with high input levels, will this be sufficiewnt to protect the input?
would anyone else be interested in this project when I am done? What else would you want to see on the board?
there is also a SSM2141 reciever, only difference is the gain. the 2143 is designed as a unity gain transmission path when used with the 2142.
5)Insert points for feedback/effects? how to best do this? leave them as unbalanced and take them before this board?
I was going to make one big 8 channel board, but for MBFM this would be overkill, of course components could be left out, I guess final board size will determine this.
I am going to breadboard the output part of this circuit as soon as I get some remaining parts for the MB SID. I don’t have the reciever chips yet, waiting for feedback on #4 above before I decide which to order.
Thanks all,
Let mem know what you think.
[SSM2142[1].pdf](< base_url >/applications/core/interface/file/attachment.php?id=4486)
[SSM2143[1].pdf](< base_url >/applications/core/interface/file/attachment.php?id=4487)
[SSM2141[1].pdf](< base_url >/applications/core/interface/file/attachment.php?id=4488)
