AOUT Settings not remembered
Hi all,
I finally got my AOUT hooked up to my MBSeq v4, and it worked first time :thumbsup:
I have run the configuration using the CV Config page and all seems OK. The only weird thing is that every time I turn on the MB Seq, it has forgotten my settings i.e. which Module I have selected PRng per CV channel etc. From the MBSEQ_HW.V4 file there is a mention of a file called MBSEQ_CV.V4, but I don’t have that on my SD Card. And I can’t find it in svn!
Would this be why my settings are not being saved? If so, where can I find that file, or should it be created automatically by MB Seq?
Thanks in advance
David
Hi all,
Thanks in advance
David
Maybe these settings are saved per session on the SD card?
No, the setting is stored in MBSEQ_GC.V4 (global configuration file), which is located in the root directory.
Could you please check if this file exists?
And when you open this file: which values are assigned to the AOUT parameters?
Hi Thorsten,
Thanks for the info. Typically, after 2 days of this behaviour - today when I turned on MBSeq it now remembers the settings :rolleyes:
I double checked the SD card and yes I have the MBSEQ_GC.V4 file and it has the settings for the CV page.
Sorry for the false alarm :slight_smile:
