Greetings,
I am working on a project to build a CV controlled Midibox SID in a Frac-rack format for my modular synthesizer. I need to build an AOUT module so that I can have the FracSid control filters, S/H circuits, etc. Problem is… AOUT uses expensive DACs that are reportedly difficult to get ahold of. I contacted Tim/Smash TV and asked if he was planning on printing up the AOUT boards, and his reply is attached below. He has a new board designed that uses cheaper/available components, and includes the SHX8 board as part of the design! He needs interest from 15 people before he would be willing to print up a batch of circuit boards - any takers/comments?
-gerald
Hi Gerald!
The short answer is no, Due to difficult availability of the DAC chip
that is used in the design.
Long answer: There is another AOUT module in the works, no idea when it
will be done (I’m not working on this one personally) but it will have
a much easier to obtain parts list.
That $30 DAC chip and the out-of-production sample & hold chips for the
SHX8 sidecar are the only reasons for the re-design. Aside from those
two issues, it’s a really great design.
You might be able to “rally the troops” in the forum to find other
people who want pro made AOUT+SHX8 boards, we would need 15 people
willing to spend $10 each to fund the fabrication run. I should be able
to save on the massive setup costs by combining the two on one board.
And you can count me in for one of these myself at this price if you
decide to go this route, so only 13 more needed. ; )
Let me know what you think!
Best
Tim aka SmashTV
