I’ve continued to troubleshoot this problem, which still persists. I couldn’t find any shorts anywhere, so I desoldered the chip and put a new one in its place, though not on the AOUT_NG board (some of the pads were damaged while desoldering) but on a daughterboard that I got from OSHpark.
I soldered this onto the AOUT_NG with wires, and tried whether the new chip gets hot. It didn’t, not even after a while, so I started recalibrating the AOUT_NG board. All went ok, calibration was finished successfully without the chip getting hot. I guess it took an hour or something.
Now I attached the seppoman SSM2044 pcb that I got from OSHpark as well, one that I made based on the PCB picture and the schematic that are available on the wiki, and started calibrating it with MB6582. Everything seemed to work, cutoff was ok, only right channel resonance wasn’t working. At this stage the chip was still ok, i.e. not hot. When I finally found what was wrong with the right channel’s resonance (C20’s legs were soldered to the same point), at the same time I noticed that the new TLV chip on the daughterboard was getting hot, and when I tried whether the filters were still working, they weren’t (I had been inspecting the filter PCB for mistakes for some time).
TLVs are kind of expensive to be fried like this while troubleshooting, so I’m not sure what the best course of action would be. I have one more chip left, it’s already soldered onto a fresh AOUT_NG board, I thought I’ll test it by attaching the complete and calibrated board to the MB6582 and leaving the power on for several hours, and if it’s still working, maybe at least the AOUT_NG is ok. After that the decision of whether to use the DIY SSM2044 board or something else is open. If people have ideas for external filters to be used with MB6582, other than self-drawn PCBs, I’m all ears :-) (Giving up on the SSM2044 would be ok for another reason too – like I found others pointing out in another thread – namely it cuts the bass when resonance is turned up.)
I don’t know if anyone has the time to check the filter PCB (in case that’s the culprit), but anyway here it is (I’m not really asking anyone to comb it through). It’s more or less a direct copy of seppoman’s board from the wiki, though it’s possible I’ve added a few mistakes
Anyway for me the mystery is that for a while everything was working, and as far as I could tell, voltages were ok (on both AOUT_NG and the filter PCB)
